Sponsored By:
Sponsored By:
Factory alarm impact SENSOR pic
Old 05-31-2011, 03:35 PM
  #46
shottel
shottel's Avatar
Mother Infiniti was no help. I have a ping into the dealership to see what they can do.
Old 06-05-2011, 03:42 PM
  #47
nishalp
nishalp's Avatar
Ok. Tried to install into a 11 Sedan and got all confused with the second wire. Instructions didnt match. Tried all the latest installs guide online but still didnt match. I did find the adapter plug going down and that kinda matched but the 2 wires on the other end of the plug didnt match. Put it back together and came to search here. Seems others having the same problem. Anyway, will try again another day but will have to probe the wires. Looking at the FSM it says the following:
1. M121 - Cavity 50 - Color BG - Trunk Lid Closed - 12 Volts when closed - 0 when open
2. M119 - Cavity 11 - Color R - Battery Power Supply - 12 Volts Constant
3. M123 - Cavity 123 - Color V - Ignition Power - 12 Volts when Ignition On
So is BG - Brown?
R - Red
V - Violet
Old 06-05-2011, 04:17 PM
  #48
tharbemiko
tharbemiko's Avatar
Are you sure you got the right instructions? I found the '10 instructions online and the install was perfectly fine.
Old 06-10-2011, 08:21 PM
  #49
htran16
htran16's Avatar
I just installed this in my 08 G coupe. does anyone know what the foam pieces that are included with the sensor for?
Old 06-11-2011, 01:05 PM
  #50
skmiller
skmiller's Avatar
So will this option finally set off the alarm if a thief punctures the door to cause the windows to roll down and thus gain entry to your vehicle? I have an 08 and have been broken into twice in this manner. Its sad because in its current state, when they do this to the car the alarm does not go off and it takes them less than 20 seconds and no one suspects that they broke into the vehicle.
Old 03-17-2012, 11:09 PM
  #51
BLamb
BLamb's Avatar
so can anyone confirm if these are the correct instructions for installing the impact sensor on a 10+?
http://www.nicoclub.com/FSM/G37/g37_...2010/1SX14.PDF
I want to get the impact sensor and install myself, but seems like many people have been having issues with the instructions not matching up.
Old 03-19-2012, 10:18 AM
  #52
BLamb
BLamb's Avatar
Just an FYI, apparently the impact sensor is now discontinued by infiniti, tried to order it and they couldn't get me one.
Old 03-19-2012, 12:03 PM
  #53
lier200a
lier200a's Avatar
Just out of curiosity... Do you guys know if the impact sensor is on the 09 G37S convertible??
Old 03-19-2012, 12:21 PM
  #54
Rad_Slinger
Rad_Slinger's Avatar
2009 INFINITI G37 Parts - Infiniti parts
Old 03-19-2012, 12:51 PM
  #55
BLamb
BLamb's Avatar
Originally Posted by Mattster
I tried ordering one from discountinfinitiparts.com, added to cart and paid for it and got this response this morning:
"Unfortunately Infiniti was having issus with the Vehicle Alarm Impact Sensor so they have discontinued it and it is no longer available. The other parts are all available."
Other parts being my splash guards/wheel locks I ordered in the same cart.
I think that part you sent me is for the airbag sensor rather than the alarm. Makes me wonder what kind of issues Infiniti was having with the sensor, I haven't seen any threads on people complaining after quite a bit of searching.
Old 03-19-2012, 01:24 PM
  #56
Rad_Slinger
Maybe. I just put in "impact sensor" and that's what it gave me.
Old 03-20-2012, 11:51 AM
  #57
nbast
nbast's Avatar
Does the impact sensor alert you if it's been triggered when you unlock your car? I had an aftermarket alarm on my Integra, and it would do a different chirp pattern if the alarm had been triggered while I was away.
I park in an over crowded lot with tight spaces at work, and would like to know if something has hit my car without doing a full 360 degree inspection...
Old 03-20-2012, 04:50 PM
  #58
GPR-37s
GPR-37s's Avatar
This is what you want...
Infiniti parts
I just installed this on my 08 works too well i had to tune it down cause it was goIng off constantly lol!
Old 03-20-2012, 05:08 PM
  #59
BLamb
BLamb's Avatar
yea, tried ordering from them as well as discountinfinitiparts.com, Neither are able to get me one ordered since they're discontinued. If you find someone who has them in stock or one for sale I'd gladly buy it.
Old 05-25-2012, 02:47 PM
  #60
Zimshimmy
Zimshimmy's Avatar
Hall Nissan of Va has 11 in stock. I just purchased one yesterday. Their phone number is 757-673-8000. Part number is 999M2 VU002. Give them a call and you might be lucky.
Quick Reply: Factory alarm impact SENSOR pic
