Stillen Transmission Cooler Kit???
If you haven't located the transmission dipstick, then look towards the firewall and the back of the upper intake manifold on the passenger side.
I thought the same thing (and I believe you are right), but the cooling is not enough for hard driving apparently. Its just that I have not even seen a DIY for this upgrade anywhere.
I found this as a DIY
Stillen 7AT coolers installed? - Nissan 370Z Forum
Does anyone know if our trans connections are 3/8 or 5/16? I wasn't sure if I needed to order these same connection parts from Summit. Please let me know thanks.
7AT-equipped cars include a trans cooler in the radiator. This is very common.
That said, more cooling is required if you track your G. I ran an event a couple of months ago, temps were in the low 80s and it was raining, yet the trans started misbehaving. I used manual mode yet the trans would sometimes upshift unbidden and ignore some downshift commands. Rather irritating.
redlinernyc
02-29-2016 11:06 PM
