Low battery indicator: weather related?
So last night I noticed that when I started my car, the low battery indicator came on for a minute. Since last night, the indicator has come on every time I have started my car. Today, I even left it running in my driveway for an hour to make sure it had a chance to charge up.
But last night my thermometer was reading -8 degrees, this morning -4 degrees, and never went above zero all day today. Could the low-battery indicator be going on because of the extreme cold and subsequent loss of battery strength? Or do you think my battery is actually low and my alternator isn't charging it properly?
My car is in my garage for the winter right now and when I start it up, I get a light with a battery and a picture of the key fob that show up. Does anyone know what this means?
It's not b'cos of the battery. It's something in the G that drainning the power out so fast after parking for 2-3 days or a week without starting up.
It has poor and weak start up everytime when i leave it for couple day.
I have Optima Red Top replace now and STILL same ploblems after try to leave it for 2-3 days. I guess it's the car!!! Infiniti should fix this issue already!!! WTF!!
For the second time since I bought this car, I am officially an idiot. My battery indicator was not on, it was my stupid keyfob battery indicator...
However, I swapped out that battery and the indicator still comes on when I start the car. Do I have to re-set the indicator light or something?
Sucks to hear some of you guys are having issues with the battery, i should consider my self lucky then because my G was parked for 3 weeks in the cold n it started right away when i came back...knock on wood :-)
Only thing i noticed was that sometimes when im backing up my rear brakes make sum noise, low pads already? or weather related? car has 6868 miles
well on the keyfob battery issue, mine has been going off again lately after replacing it a few months ago. At one point I actually had to insert my fob into the car inorder to start it. Now i get home, i pull the battery out and put it to a voltage meter.. its reading 3.13V. what gives?
