Top go stuck; freaked out!
So car was parked all day, decided to take the top down.
Started car, put the switch in down position: GOT STUCK w/the trunk open and the divider thing stuck straight up! After several stops/restarts of the engine, it only worked re-closing the roof; then the re-open was fine. Ever happen to you guys? Wondering if my batter was weak or something. Been having dead battery issue if sat >2 days. CHecked everything, and seems to be better. |
wow so its ur turn huh. seeing these threads for real the vert function is really just not reliable huh on these cars
The vert really requires a deep cycle battery. Be that as it may, if your battery goes out, when you jump the battery and start the vert you need to retrain the top, by holding the button in the closed position for 10 seconds, theN change to the open side. You also may have to retrain your windows by doing the similar process.
Originally Posted by Autocutter
(Post 4247857)
yup. 2 beeps, must cycle roof.
What Autocutter said. It's absolutely true.
