Question - Side Windows Gap Alignment
Just curious if anyone here has info on how to align the side window (driver side) with the smaller quarter window? If you’re standing outside the car looking at the two windows and where they meet, the edge of the driver window is perfect at the bottom of where they meet but too wide at the top of where they meet. (I hope this makes sense) so what I need is info how to tilt the top of the driver window toward the rear to make the gap correct.
2010 G37 Thanks guys! |
Now that I think about this more, how to “tilt” the driver window is probably the same for other models. Should I repost this elsewhere or have more patience?
I'm fairly confident that there was someone with the coup that had to do this. Try searching coup section before posting there though - these cars have been out for a long time so there must be a thread about it already.
Thanks, I’ll do that.
Picture(s)?
Can't really compare w/a coupe. Coupe has a fixed rear side window(s). |
Update: after looking at this alignment issue more I realize I made a mistake which window needs adjustment. The rear quarter panel needs the adjustment or at least that is my latest thinking. Since the travel of the rear panel turns into the main side window, I need to look at adjusting its movement tighter. I’ll need to find a thread.
