No more annoying squeaks for $10
Old 06-24-2017, 01:19 PM
muadib69
muadib69's Avatar
So, I have been putting off getting the DuPont Krytox to lubricate the seals from the top..the car is getting annoyingly lousd with squeaks. Decided to try this product and all noises are gone! Its been a couple of weeks now and the top is still quiet. A bottle is about $10, much cheaper than the $30 tube of Krytox.
The following 3 users liked this post by muadib69:
Autocutter (06-25-2017), john410312 (01-16-2020), OrigCopy (02-16-2020)
Old 06-24-2017, 07:46 PM
kiseliok
G37 Community Team
kiseliok's Avatar
I recently bought the same bottle, but haven't had a chance to apply it yet.
Can you point out a few places where you used it?
Old 06-25-2017, 02:06 AM
muadib69
muadib69's Avatar
I just followed page 5-6 on this bulletin:
http://www.infinitig37.com/TSB/ITB11-035a.pdf
The following 2 users liked this post by muadib69:
kiseliok (06-25-2017), _tjp_ (07-26-2017)
Old 07-26-2017, 06:19 PM
_tjp_
_tjp_'s Avatar
Hey, thanks for that bulletin. I haven't seen that one before.
I've been using Gummi Pflege on the rubber seals and it also does a pretty good job.
I'll try the 303 stuff next time though.
Old 04-03-2018, 08:46 AM
Autocutter
Autocutter's Avatar
Tried the 303, but now after two weeks the squeaks have returned at a much louder level!
Old 02-16-2020, 11:44 AM
OrigCopy
OrigCopy's Avatar
Big difference!
I applied it to the rubber seals on the top and it got rid of the rattles from basic rough roads and small pot holes. Only big bumps make a noise now!!!
Old 02-16-2020, 11:53 AM
john410312
john410312's Avatar
Can the little bottle of 303 with applicator be purchased at Autozone or OReillys?
TIA
Old 02-16-2020, 02:51 PM
slartibartfast
slartibartfast's Avatar
Wonder if this work on the door window channels?
Old 02-17-2020, 10:26 AM
OrigCopy
OrigCopy's Avatar
Thumbs up Amazon
TIA
Amazon303 Rubber Seal Protectant and Conditioner for Weather Seals - 3.4 fl. oz.
Amazon Amazon
john410312 (02-17-2020)
Old 02-17-2020, 10:29 AM
OrigCopy
OrigCopy's Avatar
Works the weather stripping. Dont over do it. Apply enough to see the gloss but not runny. Should apply once a month and it will start to treat the rubber and bring it back to life.
As I said before... It got rid of the constant noise but real bumps still make a noise. Our tops are multiple pieces and flex.
Old 02-17-2020, 10:33 AM
john410312
john410312's Avatar
I just bought a '10 Vert (picking it up Friday) and noticed it squeaked when I test drove it. Found it in TN and driving it back to AZ. I'll just crank the tunes until I get it home.
Old 04-16-2020, 11:29 AM
noles1800
noles1800's Avatar
Great topic and thanks for the seal recommendation and pdf!!!!
Old 04-16-2020, 12:58 PM
dwb993
dwb993's Avatar
Honda Shin-Etsu Silicone grease (P/N: 08798-9013) is a twice yearly application.
Clean all rubber with wet towel (it will get very dirty). Apply a thin layer of Shin-Etsu. You an use your finger or a folded paper towel. Just a dab will do - no need to over apply. If you see any white, it is applied too thick.
Use on all rubber seals and weatherstrip.
I use this regularly on my S2000 seals. Other cars in the fleet get it as needed.
EDIT: Just looked at the PDF. Krytox appears to also be a silicone grease. Same stuff as the Honda Shin-Etsu grease.
303 is too thin (a liquid) which is why it does not last.
