MyG37
MyG37 (https://www.myg37.com/forums/)
-   G37 Convertible (https://www.myg37.com/forums/g37-convertible-349/)
-   -   Top won't move :( (https://www.myg37.com/forums/g37-convertible/245015-top-wont-move.html)
colnajoe Mar 12, 2013 03:01 PM
Top won't move :(
So I opened the top half way to lube the seals and weatherstriping. As I'm doing this, I watch the top slowly sag into the trunk. I start the car to close the roof, and it stops saying the trunk is open. Of course it's open, the top was opening up! So now I can't get it to move up or down, each time saying trunk is open. Battery is unplugged now, hoping I can reset the timing....if not, 22 mile trip to dealer, 34 degrees, and the truck is flipped open for opening. I fear a tow to the shop unless someone has a handy little trick to reset the tioming so I can move this top. NOOB LESSON LEARNED, DANG IT!!!
zdubin Mar 12, 2013 03:42 PM
Call the dealer and ask them what to do? Maybe they can tow it backwards on a flatbed? This way the wind will pass over the outside of the top rather than through the cabin. I'm sure the dealer would know what to do.
colnajoe Mar 12, 2013 05:00 PM
Well roadside assistance is enroute, 2 hour wait. It will be towed just like you described, but its snowing right now...hope that it stops for the 20 mile piggy back. Dealer needs to hook it up to a consult 3 to find out what actually needs to be done. What a wierd thing to have happen. I had the top half closed and went into the garage to get the dry lube, 30 seconds later saw that the top had sunk into the trunk about 8 inches. I guess once that happens, your screwed...
DIDN'T SEE THAT IN THE OWNERS MANUAL...............
JerseyG37s Mar 12, 2013 05:26 PM
tell me you turned the car off with the roof in the air?
colnajoe Mar 12, 2013 08:15 PM
Yes sir, I did....
colnajoe Mar 12, 2013 08:18 PM
Got back from the dealership, with a loaner.... Tech used consult 3 to manuver the top up, and then I saw the 4 HUGE DENTS IN ONE OF THE ROOF PANELS... Tech still could not get ther top[ to go up or down using the button, still beeping. Gonna check it out more in the morning
zdubin Mar 12, 2013 09:10 PM
uy gevalt! I hope the dealer resolves everything for you.
JerseyG37s Mar 13, 2013 08:35 AM
youre going to have 4 large dents in the roof....you should never turn the car off while the roof is in motion always leave it running and the 4 huge dents are because he basically slammed into the truck... it will be there for a while because when they finially fix the roof... they then need to paint the roof top. i hope you didnt tell them you truned the car off midway through and you told them this just happened.... good luck buddy
J0KER Mar 13, 2013 09:30 AM
LOL.... I thought I was the only Jew that drove an Infiniti! We would be more at home in the MBenz forums.
Also the correct spelling would be Oy*
JerseyG37s Mar 13, 2013 09:40 AM
LMAO!!! that is ****ing funny
colnajoe Mar 13, 2013 11:08 AM
Must admit, I had to look it up....... I found that it closely matched "good grief", which fits perfectly
JerseyG37s Mar 13, 2013 11:29 AM
איך האָפֿן איר פאַרריכטן דיין קאַנווערטאַבאַל אנטשולדיגט צו הערן וועגן די שפּיץ
just wanted to respond to the jewish guy on here lol
zdubin Mar 13, 2013 11:52 AM
That's Yiddush (a combination of Hebrew and German)! I can't ask my grandmother to translate, shes been gone for 15 years. Google translate spit out this: "I hope you fix your Convertible sorry to hear about the top"
JerseyG37s Mar 13, 2013 11:54 AM
im sorry to hear about your grandmother may she rest in peace sir!!
colnajoe Mar 13, 2013 12:30 PM
Well, just got a call from the stealership. They are calling it an "adjustment" and therefore only covered for 12 mos or 12K. I am still under factory warranty, but They want me to pay 135 for the adjustment, and not covering the damage to the roof panel. Not happy, called consumer affairs, complaint filed.....I've never had any luck going against the stealership. 9th Nissan / Infiniti owned, very disapointed....
© 2026 MH Sub I, LLC dba Internet Brands
