List of ITBs for verts- FYI ONLY
New owner and not sure if ITBs have been done
Hello, I just bought a certified pre-owned 2011 G37S Limited Edition. How do I know if these ITBs have been completed on my G? If they have not are they covered by my warrenty? Thanks
Where csn i fint these itbs
[QUOTE=cvipgo;3183344]The following ITBs are for your information only - may not be applicable to your vert.
ITB
Number Date Title
11-003 01/14/2011 Navigation System - Map Data Update Matrix
10-023A 01/06/2011 TPMS/Keyless Systems - Signal TECH II Diagnostic Tool
10-074 12/15/2010 ABS/TCS - CAN Diagnostic Information
10-071 11/12/2010 Interior - Rattle Noise From Rear Headliner Area
10-070 11/11/2010 Body - Convertible Top Water Leak At Windshield Header
10-069 11/05/2010 Body/Interior - Convertible Top Headliner Service Info.
09-012B 11/03/2010 Emissions - EVAP System DTC Diagnostics
10-067 10/21/2010 Steering/Suspension - Wheel Bearing Collision Damage
10-011A 10/19/2010 Body - Door Accent Garnish Replacement
09-050A 09/30/2010 Tire Monitor System - Warning Lamp Diagnostics
10-059 09/10/2010 Antitheft System - NATS Security VBC Logic
10-010C 09/07/2010 Engine Controls - Low Battery Voltage/No Start
10-056 08/24/2010 ABS/TCS - Wheel Speed Sensor Diagnostics
10-048 07/30/2010 Engine - Oil Level Is Too Low/Unusual Engine Noises
10-044 07/09/2010 Body - Convertible Top/Trunk CONSULT III Work Support
10-027A 06/29/2010 Lighting - Xenon Headlamp Service Info.
10-038 06/21/2010 Engine Controls - ECM Programming Interruption Recovery
10-039 06/21/2010 Electrical - MIL ON/DTC P0128 Due To Remote Start Sys.
09-029A 05/14/2010 Cooling System - Long Life Coolant Information
10-029 05/07/2010 Computers/Control - CAN Code, Diagnostic Tips/Guidelines
10-021 03/11/2010 Electrical - JIS/CCA Battery Testing Information
99-037P 03/11/2010 Electrical - Battery/Starting/Charging Sys. Testing
10-006A 02/11/2010 A/T - 5 Speed A/T DTC Diagnostics
10-004A 01/26/2010 A/T, Interior - A/T Vinyl Shifter Boot Comes Loose
10-012 01/21/2010 A/T - 7 Speed A/T, Fluid Level Checking/Filling
10-008 01/19/2010 Engine Controls - Seized O2 Sensor Removal Procedure
10-005 01/12/2010 Engine - Drive Belt Noise Diagnostics
03-051E 01/04/2010 Lighting - Exterior Lamp Fogging Inspection
08-021B 12/11/2009 Navigation System - HDD Navigation Map Data Updating
09-067 12/08/2009 Engine - Reman Engine Start Up Lubrication Information
09-066 12/03/2009 Body - Power Window Switch/Window Regulator Replacement
09-063 11/18/2009 Vehicle - VIN Plate/Certification Label Replacement
09-062 11/17/2009 Emissions - EVAP Canister Vent Control Valve Replacement
09-059 10/28/2009 Keyless Systems - Intelligent Key(R) Battery Replacement
08-015A 10/16/2009 Tires - Tire Pressure Information
HI,
I just bought a used convertible and i was wondering where can i find a pdf version of these itbs? It wud be great help if someone can email it to me. nabilnoor@hotmail.com.
thanks
ITB
Number Date Title
HI,
thanks
timc00k
02-15-2017 09:15 AM
ck1109
10-15-2015 11:06 PM
