mods4cars smarttop install on an Infiniti g37 convertible
#91
Mr. Drop it like it's hot
hey men, replied on your fb with:
Nothing special Eric, I just told them that I had the car for six months and the front seats looks like its been used for 4years. So they told me to bring it in and guess they compared it to the passenger front seats and knew it wasn't wear and tear. If u have the same issue, try ur luck.
Anyway......... back on topic.
So I got a response from Stefan and was asked to check my LED status and I think it is good. This was just confirmed OK.
<object width="640" height="480"><param name="movie" value="http://www.youtube.com/v/Z3-jfc8HntI?version=3&hl=en_US&hd=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/Z3-jfc8HntI?version=3&hl=en_US&hd=1" type="application/x-shockwave-flash" width="640" height="480" allowscriptaccess="always" allowfullscreen="true"></embed></object>
Based on my interpretation, I think it is blinking normally and not erratically.
Noted in the last correspondence was possible battery issues. The car has been idle for 3 days, driven 30 minutes on day 4, then the install on day 5.
Side note the back panel is out of alignment and not laying flat by the back window with the top up. Sounds like time for a roof reset at the dealer. I'll have them check the battery also and go from there after the roof is reset.
#92
I wonder if I can get my seat replaced like that LOL . The sport seat design causes a lot of friction getting it and out of the car. I may have to change the way I enter and exist the car, both feet at a time and turn..
What are your setting on the module anyways. Also make sure that you are giving the time interval between pressing the between in the key fob for at least a second in between.
Does the windows down command from the key fob work with the car off?
#93
Yeah, I can remember something like this happening where the roof would not work with the car off. It turned out to be the battery. This was from a cold start, in the morning after installing the until. Probably check with the dealer on the battery level.
Fn 1 at 1
Fn 2 at 3
Fn 3 at 3
Fn 4 at 3
Fn 5 at 1
Fn 6 at 2
Fn 7 at 0
key:
mods4cars product manual
I believe I gave it enough time, but I've also noticed the low keyfob battery warning indicator, so that may be a factor. The battery is fine, just needs the normal charging via driving around and the roof is fine too, no reset needed there. I've not had a chance to give it another try as yet. Likley tomorrow after some driving around.
#94
Gotta get the battery charged. It worked halfway to drop the top after some driving when using the key fob, but the back panel did not retract and I needed to use the door button to complete the drop.
update:
Battery tested fine at autozone 530 CCA today. Checked with infiniti on that the rating should be and they said 575 for the stock battery. I inquired about the upgraded battery which is rated at 710 CCA. I am figuring on upgrading to get the module working.
update:
#96
So.. after checking around, the KP Technologies roll up module has support for rolling up the windows on the US spec G's. I'm wondering if there would be any compatibility issues with using this (two clicks with the lock botton) with the smarttop??
Anyone want to give this a try?
KP Technologies
So I am figuring, the roof is already down.
1) 3 clicks (1 second interval on the lock button) to bring with roof up to closed postion and the back windows up, then
2) 2 clicks (for the kp tech module) to bring up the front windows and if needed one click to lock the car if it's not already locked.
This review
https://www.myg37.com/forums/audio-v...up-module.html
and this guide
http://kptechnologies.com/forums/vie...php?f=2&t=1075
was referenced.
KP Technologies
This review
and this guide
was referenced.
#97
[quote=cereal2k;3319117]So.. after checking around, the KP Technologies roll up module has support for rolling up the windows on the US spec G's. I'm wondering if there would be any compatibility issues with using this (two clicks with the lock botton) with the smarttop??
KP Technologies
1) 3 clicks (1 second interval on the lock button) to bring with roof up to closed position and the back windows up, then
The fact that KP can bring up the fronts with the FOB sounds promising. Makes me wonder if Mods4Cars can still find a way. It should still be the goal to have everything up with one command.
KP Technologies
#98
KP Technologies
This review
and this guide
KPtechnologies Forums • View topic - Infiniti G37 Coupe Install Details
was referenced.
KP Technologies
This review
and this guide
was referenced.
But men, this kp tech is very promising as mentioned. Only thing I really dont like is the installation of having to splice. wish it was more plug and play. But if the two modules can work together that would be awesome.
I wouldnt mind giving it a try perhaps in the future, only thing scaring me is the installation.
#99
I don't think they have any solution for the current product they have. There is a note stating it works with Euro Spec and I will assume Gulf Spec verts. So apart from a European ECU flash, it seems the KP tech module would be the other method. I too one like one solution.
#100
hey men. i am glad that you were able to get your module taken care of. would have sucked if the module didnt work.
I had put the roof and windows up (3 clicks on the lock button). Then I used the key to close the windows. Then after a short time, used the keyfob to lower the roof and windows.
It stopped halfway (backpanel did not go down). The wife was with me and she had her keyfob in the car at the time with a low battery reading.
edit: video added
<object width="853" height="480"><param name="movie" value="http://www.youtube.com/v/M89xLWxgJc8?version=3&hl=en_US&hd=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/M89xLWxgJc8?version=3&hl=en_US&hd=1" type="application/x-shockwave-flash" width="853" height="480" allowscriptaccess="always" allowfullscreen="true"></embed></object>
So since I've gotten home (I've been driving in the mountains for half a day) I had the top down and windows up.
3 clicks with the off button (1 sec interval) did not close the roof. Once I lowered all 4 windows, then the sequence worked to close the roof, then raise the back windows.
edit: video added
<object width="853" height="480"><param name="movie" value="http://www.youtube.com/v/QgM3uc6q7Mg?version=3&hl=en_US&hd=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/QgM3uc6q7Mg?version=3&hl=en_US&hd=1" type="application/x-shockwave-flash" width="853" height="480" allowscriptaccess="always" allowfullscreen="true"></embed></object>
I've just again tried to lower the roof where the starting point is with the roof already up, and all windows are up, but it has stopped halfway again. Once change I will make is to not have the hazards on and go from there.
#102
That sounds exciting. I've gotten used to the key in the door work around. The only other thing I find anoying with the Mods4Cars device is when I go to unlock my passenger door by second clicking my door I also get a all windows down command. It unlocks the other door OK but brings less than lovely comments from the wife on rainy days. Again a work around, make her wait till I open my door and reach in for the unlock button.
#103
Found a work around to the top down cycle not completing with the key fob. Just restart the cycle from the keyfob and it will complete.
So this happened today
So top is up, windows up, just two clicks gets the windows down this time. Then 3 clicks for the top down. Then it stops half way, then I do 3 more clicks (I may not have to do so many) then 3 more clicks on unlock button and it completes the cycle.
I should just be able to do 3 clicks and have the windows and top down from this list
"Tap open 2x (in 1 sec intervals) to open all windows.
Tap open 3x to open the top and bring the windows into the selected position (WU=Windows Up, WD=Windows Down).
Tap open 4x to open the top and bring the windows into the opposite position this one time (Down on settings 1 and 3, Up on settings 2 and 4).
Tap close 2x (in 1 sec intervals) to close all windows.
Tap close 3x to close top and windows.
Tap close 4x to close only the top and leave the windows open.
Tap in the same direction at any time to immediately stop an ongoing operation."
Now I happened to be in the car when the second restart of the unlock sequence from the key fob was run and I saw this the Nav Screen "Configuration failed because CONSULT is connected.". It quickly disappeared.
This is a vid of the work around until the support connection is made to the module.
<object width="640" height="480"><param name="movie" value="http://www.youtube.com/v/OIQN27zRark?version=3&hl=en_US"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/OIQN27zRark?version=3&hl=en_US" type="application/x-shockwave-flash" width="640" height="480" allowscriptaccess="always" allowfullscreen="true"></embed></object>
#104
Yeah, in about a week and a half I'll sync up with them to see what's happening.
#105
Not good Cereal2k, the top appears to have stopped for an unknown reason but the module was still in progress (lights still flashing). You 3 clicked and that stopped the module (I bet you could have just one clicked, any touch of the fob or button while the top is moving will stop it). You then restarted it and it worked. Try disabling the mod and run the top several times factory to make sure a sensor or something is not interfering. In the end, I suspect a flaky module.
