IPP Engine packages at GREAT Prices
For those of you who do not know us, we have been racing and building Nissan's and Infiniti's for 20+ years now. Kyle owned and built one of the fastest Nissan 300zx street cars in 1999 that held the 1/4 mile record until just a few years ago. The machine shop that does the machining of the engines has done some of the highest HP VG30DETT, VQ35, and VQ37VHR motors in the nation.
Because of the Volume of motors we do, we have some of the best pricing on motor builds around. That being said we have several engine packages that are sure to fit your budget and goals. Here is what we have to offer(parts in italics are upgraded from previous stage): https://cimg1.ibsrv.net/gimg/www.myg...32e86bb856.gif Short Block Packages Stage 1 Short Block Package: Wiseco or JE Pistons .020 over Eagle H Beam Rods ARP Rod Bolts Block inspected and cleaned Block redecked Block Bored and Honed using a Torque Plate Rotating assembly balanced Crank magnafluxed and the journals micro-polished New Moly coated Race Spec main bearings installed New Moly coated Race Spec rod bearings installed Block prepped and assembled This package runs only $3435 and can be purchased or get to get more details click Here Stage 2 Short Block Package: Wiseco or JE Pistons .020 over Carillo H Beam Rods ARP WMC 3/8" Rod Bolts ARP Main Bolts Block inspected and cleaned Block redecked Block Bored and Honed using a Torque Plate Rotating assembly balanced Crank magnafluxed and the journals micro-polished New Moly coated Race Spec main bearings installed New Moly coated Race Spec rod bearings installed Block prepped and assembled This package runs only $4399 and can be purchased or get to get more details click Here Stage 3 Short Block Package: Wiseco or JE Pistons .020 over Carillo H Beam Rods ARP WMC 3/8" Rod Bolts ARP Main Bolts Darton Sleeves installed with CNC Block inspected and cleaned Block redecked Block Bored and Honed using a Torque Plate Rotating assembly balanced Crank magnafluxed and the journals micro-polished New Moly coated Race Spec main bearings installed New Moly coated Race Spec rod bearings installed Block prepped and assembled This package runs only $6899 and can be purchased or get to get more details click Here https://cimg8.ibsrv.net/gimg/www.myg...aad632f11a.jpg Head Packages Stage 1 Head Package: Heads inspected and cleaned Heads redecked Ported exhaust and intake runners 3 angle valve job New OEM Valve stem seals installed Valve Stem Heights set Cold Clearance set for stock cams Heads prepped and assembled This package runs only $1895 and can be purchased or get to get more details click Here Stage 2 Head Package Jim Wolf Technology(JWT) Exhaust Cams JWT High RPM Valve Spring JWT Valve Spring Shim JWT Extended Cam Sprocket Bolts JWT Cam Sprocket Bolt Washer JWT Rear Camshaft Bolt JWT Cam Bolt Seal - Copper Heads inspected and cleaned Heads redecked Ported exhaust and intake runners 5 angle valve job New OEM Valve stem seals installed Valve Stem Heights set Cold Clearance set for stock cams Heads prepped and assembled This package runs only $2950 and can be purchased or get to get more details click Here https://cimg4.ibsrv.net/gimg/www.myg...6f914cf8ea.gif Long Block Packages Stage 1 Long Block Package: Wiseco or JE Pistons .020 over Eagle H Beam Rods ARP Rod Bolts Block inspected and cleaned Block redecked Block Bored and Honed using a Torque Plate Rotating assembly balanced Crank magnafluxed and the journals micro-polished New Moly coated Race Spec main bearings installed New Moly coated Race Spec rod bearings installed Block prepped and assembled New OEM Head Gaskets Heads inspected and cleaned Heads redecked Ported exhaust and intake runners 3 angle valve job New OEM Valve stem seals installed Valve Stem Heights set Cold Clearance set for stock cams Heads prepped and assembled New OEM Oil Pump This package runs only $5850 and can be purchased or get to get more details click Here Stage 2 Long Block Package: Wiseco or JE Pistons .020 over Eagle H Beam Rods ARP Rod Bolts Block inspected and cleaned Block redecked Block Bored and Honed using a Torque Plate Rotating assembly balanced Crank magnafluxed and the journals micro-polished New Moly coated Race Spec main bearings installed New Moly coated Race Spec rod bearings installed Block prepped and assembled New OEM Head Gaskets Jim Wolf Technology(JWT) Exhaust Cams JWT High RPM Valve Spring JWT Valve Spring Shim JWT Extended Cam Sprocket Bolts JWT Cam Sprocket Bolt Washer JWT Rear Camshaft Bolt JWT Cam Bolt Seal - Copper Heads inspected and cleaned Heads redecked Ported exhaust and intake runners 5 angle valve job New OEM Valve stem seals installed Valve Stem Heights set Cold Clearance set for stock cams Heads prepped and assembled New OEM Oil Pump This package runs only $6880 and can be purchased or get to get more details click Here Stage 3 Long Block Package: Wiseco or JE Pistons .020 over Carillo H Beam Rods ARP WMC 3/8" Rod Bolts ARP L19 Head Bolts Block inspected and cleaned Block redecked Block Bored and Honed using a Torque Plate Rotating assembly balanced Crank magnafluxed and the journals micro-polished New Moly coated Race Spec main bearings installed New Moly coated Race Spec rod bearings installed Block prepped and assembled Cosworth Head Gaskets Heads inspected and cleaned Heads redecked Ported exhaust and intake runners 3 angle valve job New OEM Valve stem seals installed Valve Stem Heights set Cold Clearance set for stock cams Heads prepped and assembled New OEM Oil Pump This package runs only $7630 and can be purchased or get to get more details click Here Stage 4 Long Block Package: Wiseco or JE Pistons .020 over Carillo H Beam Rods ARP WMC 3/8" Rod Bolts ARP L19 Head Bolts Block inspected and cleaned Block redecked Block Bored and Honed using a Torque Plate Rotating assembly balanced Crank magnafluxed and the journals micro-polished New Moly coated Race Spec main bearings installed New Moly coated Race Spec rod bearings installed Block prepped and assembled Cometic Head Gaskets Jim Wolf Technology(JWT) Exhaust Cams JWT High RPM Valve Spring JWT Valve Spring Shim JWT Extended Cam Sprocket Bolts JWT Cam Sprocket Bolt Washer JWT Rear Camshaft Bolt JWT Cam Bolt Seal - Copper Heads inspected and cleaned Heads redecked Ported exhaust and intake runners 5 angle valve job New OEM Valve stem seals installed Valve Stem Heights set Cold Clearance set for stock cams Heads prepped and assembled New OEM Oil Pump This package runs only $8660 and can be purchased or get to get more details click Here Of course these are just the packages we have put together. Any package can be added to or subtracted from to meet and goals or parts your heart desires. Feel free to call me, email me, or IM me at anytime to discuss your goals and needs. |
Still rocking this deal!!
Best deals....Best customer service :driving:
Hello I am doing research for a build that I want to do and I have a question about this. If the car is not FI'd how much HP would this give?
Originally Posted by Sunny G
(Post 3790466)
PM me with any questions you have about our builds
