MyG37
MyG37 (https://www.myg37.com/forums/)
-   Engine, Intake and Exhaust (https://www.myg37.com/forums/engine-intake-and-exhaust-401/)
-   -   Help Car looses power immediately after turning off and can't turn on or unlock (https://www.myg37.com/forums/engine-intake-and-exhaust/299459-car-looses-power-immediately-after-turning-off-and-cant-turn-on-or-unlock.html)
pkolla May 30, 2021 08:10 AM
Hi
I had a weird problem last evening, it happened twice.
I was able to drive the car to my destination which is an hr away and turned off the engine. Immediately after stopping the engine, the car lost power, I couldn't even unlock the doors from inside the car(usually the doors unlocked by itself). I can't even turn the engine back on. But if I give it like 10-15 mins, it got the power back and I am able to turn on the engine. While driving after I turn on, I felt something weird with acceleration. Like it's jumping the gear or not getting enough power to move.
the battery is less than a yr or 2 old. I am not sure if it's the starter or ignition problem. This is 2013 infiniti g37x all wheel drive.
I haven't done any maintenance on starter , ignition or spark plugs after buying from dealer. It has around 75k miles on it.
stealthee May 30, 2021 09:19 AM
Check your battery connections.
pkolla May 30, 2021 12:48 PM
battery connection seems to be fine.
if the engine is cold, it turns on and off fine. I tried turning on and off this morning and seems to be fine.
© 2026 MH Sub I, LLC dba Internet Brands
