Engine, Intake and Exhaust Subforum dedicated to breather or engine mods (intakes, exhaust, pulleys, N/A mods etc.)
Review Stillen CAI Generation 3 Thoughts, Dyno, and Vid with Berk HFC & FI Carbon Exhaust
Old 10-29-2008, 06:02 PM
  #46
Carlitos_SS
Carlitos_SS's Avatar
BTW... didn't part of this Stillen testing include using a bone stock car? Do we have those results, yet? Just wondering...
'Los
Old 10-29-2008, 06:25 PM
  #47
AZg37
AZg37's Avatar
when modding a NA car vs. a F.I. car mods will produce different gains, that part is correct. In the case of our cars, and the gains of a modded set-up vs. a stock setup, you will gain more hp from this intake on an unmodded car. The reason for this is when the car is stock, it isn't as efficient as it could be, the flow of the intake and exhaust is not perfectly designed. All parts that we install are designed for stock set-up's, and the gains listed by manufactures are reflecting an un-modded car. You can only increase the efficiency and flow of our cars to a certain point. When I installed my HFC's, I saw a significant gain in HP, but the cat-back and headers gains were less then advertised because I installed them on a modded car, with the exhaust flow already altered. You cannot stack HP gains from manufactures, that would not be accurate. If you read exhaust gives you 15hp, HFC give you 15, intake gives you 15, and headers give you 10, installing these will not give you 55hp. You'll probably see closer to 35 to 40hp, because the parts have less of an impact when installed in conjunction with other performance parts that change our cars chemistry.
Old 10-29-2008, 06:40 PM
  #48
Carlitos_SS
I was wondering if there would be a difference in NA vs FI, but I had already posted...
'Los
Old 11-01-2008, 09:52 AM
  #49
KAHBOOM
Super Moderator of Pwnage
KAHBOOM's Avatar
Excellent write up... It's good to see gains accross the RPM range.
Old 11-01-2008, 01:29 PM
  #50
NJlakeshoreG
NJlakeshoreG's Avatar
well put!!!!
Old 11-01-2008, 03:58 PM
  #51
tlon19
tlon19's Avatar
now if u get tuned u will get numbers like me =]
Old 11-03-2008, 02:51 AM
  #52
bboysteele
bboysteele's Avatar
Did you ever post your dyno sheet? Not trying to be mean but I have seen some crappy tunes from Technosquare. The tunes were what the customer wanted but they were bad tunes none the less. Lots of power on the top end but a huge loss on the bottom end.
Old 11-03-2008, 01:13 PM
  #53
christian655321
christian655321's Avatar
nice to know it makes power for sure.
it did feel stronger as I experienced also.
for all of you that are doing the upgrade from v2 to v3 - you will receive a stillen credit - not a credit refund on your credit card. Found this out yesterday. It was explained to me differently when I placed my order but I am okay with it. Just an FYI for the rest of you.
Old 02-03-2009, 11:45 AM
  #54
VONYC
VONYC's Avatar
i know this is an old thread but i didnt want to start a new one .. i have a quick question .. i have a FI exahust .. if i throw in the FI HFC will i lose low end ? or lose anything for that matter?
thanks
Old 03-11-2009, 12:24 AM
  #55
heff
heff's Avatar
thanks
i wana know the same thing! ANY VIDS OUT THERE OF THIS???
Old 03-11-2009, 12:29 AM
  #56
cvt
cvt's Avatar
can you show me a link? Technosquare has been one of the best VQ tuners around...
Old 03-21-2014, 01:33 PM
  #57
xorbitman
xorbitman's Avatar
That's what I call "RICER" math when the civic kids add all the gains from the aftermarket parts and think it's a linear thing....LOL!
Old 08-03-2015, 10:44 PM
  #58
Sway_NV
I'm too young to die!
Sway_NV's Avatar
Great review. Can't wait to get mine installed.
Old 08-23-2015, 09:32 PM
  #59
jfisher
jfisher's Avatar
I don't mean to be a negative nancy, but maybe I'm looking at a different graph than everyone else. This system doesn't pickup much more than a couple whp under the curve and even loses power in some areas. The only gains are from 6500 - 7500rpm. If anyone thinks they can "feel the power" the dyno proves otherwise. I can think of a lot better ways to spend $560.
chuckie311
78
04-18-2016 08:56 PM
RoyalG37
08-19-2015 03:36 PM
Jensen Mathew
08-16-2015 08:06 PM
Ihtbealexxx
Intake and Exhaust
08-09-2015 08:45 AM
Quick Reply: Review Stillen CAI Generation 3 Thoughts, Dyno, and Vid with Berk HFC & FI Carbon Exhaust
