white smoke with sweet smell on cold starts
If I remember correctly, the throttle bodies are supplied with coolant, ostensibly to prevent icing.
OP, I think there are test strips that will reveal if there are hydrocarbons in the coolant. If exhaust is mixing with coolant, you have a failed head gasket and/or cracked head.
Infiniti cars are very few here in the city I live and there is no good mechanic who has experience with the cars and their components
It is confusing though that you state there is no coolant loss.
venkatasai1989 (02-13-2019)
You can buy a pump that screws to the radiator to pressurize the cooling system and perform a leak-down test. It's possible that if there is a cracked head, the crack might be at a valve seat that will stop the leak if the valve is closed.
once again, thank you for responding
lektrix
09-23-2018 03:04 PM
FourOneFive
09-25-2011 07:37 PM
toastmaster
11-10-2010 03:57 PM
