installing VLSD - is this a problem?
Hi,
Laugh if you want but I really don't know. I have an automatic 2013 Journey. I got a VLSD from an automatic 2011 G37S and was going to install Whiteline bushings. (What a PITA removing that rear bushing!)
Anyway, I haven't installed the VLSD, yet. I got it used. I just noticed one of the extentions on the flange for the bolts is bent. My guess would be someone dropped it. I don't think this would matter, but I attached a picture.
If it's just cosmetic, I don't care. But could this cause the car to vibrate? If it is a problem, can I take the flange off of my open differential and use it?
My understanding is that this all bolts up but you need bolts because you now have holes on the CV axles and the flanges. I got some grade 8 bolts for that.
You're going to need to get that flange straightened so it can be bolted to the driveshaft. And to eliminate possibility of vibration. 7AT and 6MT driveshafts use different flanges, so as long as both flanges come from the same style of transmission, you should have no issue swapping the flange.
Use this opportunity to replace the diff bushing with urethane. NVH increase is negligible and it will eliminate the need for future replacement. Those fluid-filled bushings just don't seem to last all that long.
orava (06-19-2018)
Thanks.
I was exhausted when I wrote this yesterday because I'd been messing with removing the old bushings for hours so I wasn't totally clear. I plan on going with urethane bushings.
Both diffs are 3.3 and from 7ATs. I don't drift my car, I just want better traction when I accelerate. This is my daily driver.
I tried to find out how to remove a side flange so I can use my old one but wasn't able to. My understanding is that there is a clip somewhere. Do you open up the cover or do you just hit it hard enough from the outside to knock it out?
Really appreciate it.
Thanks,
Darian
Thanks,
Darian
good luck
orava (06-19-2018)
Alagator28
17
06-08-2018 02:51 PM
