Transmission slipping 09 G37x
Code shows 3rd and 4th gear malfunction. Car only books for around 9k with 137k miles on it. Trying to determine whether I should try a tranny swap or sell it? Anyone with similar issues?
Originally Posted by HGH
(Post 4193100)
Mine revs up around 4 to 5k before going to 2nd. It will shift fine thru all gears if I feather the pedal. If I try to drive normal or aggessive it will throw the car into neutral. I then have to turn off the car then start it back up. Drives fine again until I get into the throttle. It also lags before take off. Like it doesn't know its in gear. Took it to Nissan dealer who said it needs a transmission. Not sure what direction to go with it.
Did Nissan hook up their Consult device to check for codes? If not, take it to Nissan or Infiniti to have them do it. It very well could need replacing. Or have TSBs applied. You won't know until the code check.
Yes they did full diag checked fluid level...
My transmission is starting to slip too! 2011 g37 sedan rwd 60k miles, it's quite sad because the radiator cracked too. I had to replace the radiator and flush the tranny 3 times and it's still slipping. The new transmission costs 10k o-o
Originally Posted by darklordsep
(Post 4198701)
Since trans cooker runs through radiator you might need to do small rebuild on trans
