G37 - Triptonic issue
Old 01-16-2018, 10:45 PM
Frodo88
Frodo88's Avatar
Hi,
Recently purchased a G37 Type SP with the paddles for gear change - purchased second hand for dirt cheap so expected a few issues...
Circumstances
On start up can change from 'D' into 'D' and will display gear '1' on dash. When you go to drive or change gear it will automatically revert to drive and won't go back into 'DS' on screen (physically will go into spot). So it appears the paddles are not working for some reason...anyone had this issue or know the cause?
Regards,
Frodo
Old 01-16-2018, 11:05 PM
PNW_IPL
PNW_IPL's Avatar
Go into ds then tap a paddle to get manual mode. Should stay in manual mode
Old 01-17-2018, 01:06 AM
Frodo88
Frodo88's Avatar
Hi,
I've done that - put it into DS and pull the paddle and displays gear '1'. Start driving and engine revs up - when it gets to about 4k it automatically shifts and then reverts to 'D'. Pulling the paddles in that interim part does nothing.
I've been reading that it might be a fuse or switch that controls the paddles? any idea if that is correct and where it is located.
Regards,
Frodo
Old 01-17-2018, 01:08 PM
terribleone
terribleone's Avatar
There is a sensor in your gear shift assembly that is failing (or failed). I had this happen (and others have too), I replaced the entire shift assembly and fixed it.
ANMVQ (01-19-2018)
Old 01-19-2018, 09:25 AM
ANMVQ
ANMVQ's Avatar
^^^ was just going to day this, I had the same thing happen, dealer changed the whole thing( I had warranty tho) so no clue how much it was.
SON415
06-02-2015 05:27 PM
chuckbaht
18
08-07-2008 05:25 PM
Sharx59
Intake and Exhaust
12
07-17-2008 01:15 AM
tomcat146
35
02-27-2008 11:54 PM
mygiantcircle
06-27-2007 12:01 AM
Quick Reply: G37 - Triptonic issue
