ABS, Slip, AWD, VDC, Brake, TPMS and Key Light all ON
So all these lights stay ON, even with the car started.
The usual suspects are brake fluid LOW, this is not the case. Yesterday I did some brake maintenance, such as lubing caliper pins and a full brake fluid flush. I did not remove the negative battery terminal, instead I disconnected the ABS module connector, near the brake fluid reservoir. I did encounter some trouble in removing the bottom caliper pin of the passenger rear brakes, it was bone dry, so I used a hammer (top caliper pin already removed) against the caliper to force the bottom pin out. After the lubing of pins and brake fluid flush, reconnected the ABS module connector, when I start the car, all the ABS, Slip, AWD, VDC, Brake, TPMS and Key Light now stay ON. I don't know why the Key light is ON when that had nothing to do with the brakes. The steering wheel doesn't lock now after the car is in OFF. Next I will check the wheel sensor on the rear corner I used the hammer on. Any help would be appreciated as I want to go to the dealer as a last resort. https://cimg6.ibsrv.net/gimg/www.myg...5f14bd2dec.jpg |
OMG what rookie mistake. It turned out to be the ABS module connector. It seemed like it was connected, or so I thought, so I fiddled with it and made absolutely sure it was this time, and when I fired her up, all lights went off!
I've bled brakes on Infiniti's before, except this was the first time I disconnected the ABS module connector and lesson learned now, make sure it is fully fully reconnected afterwards! A good indicator to my problems for anyone else is that how can doing brake maintenance affect the Key dash light for steering wheel lock? It shouldn't be related so to check what was done electrically for the culprit. Sorry to have cried wolf, but this really stressed me out! |
Glad you figured it out!!!. it made me cringe reading this!
Your dash was starting to resemble a GTI's :icon17:
https://encrypted-tbn0.gstatic.com/i...6JLK_zo9BhAy-g |
Originally Posted by Ryus
(Post 4135587)
I've bled brakes on Infiniti's before, except this was the first time I disconnected the ABS module connector and lesson learned now, make sure it is fully fully reconnected afterwards! A good indicator to my problems for anyone else is that how can doing brake maintenance affect the Key dash light for steering wheel lock? It shouldn't be related so to check what was done electrically for the culprit. Sorry to have cried wolf, but this really stressed me out! Thanks! |
It's not an opinion that low brake fluid will cause the ABS and VDC lights to come on. It's a fact. Happened to me last month.
Yes, there may be other culprits, but these two are known. |
(Post 4181837)
