Go Back  MyG37 > Tech Area > Engine, Drivetrain & Forced-Induction
Reload this Page >
Help Weird high pitch noise on G37x 2012 Auto on highway speeds 70-80+ mph
Notices
Old 11-09-2016, 03:21 PM
si_driver
Liked 34 Times in 27 Posts
Another 2012 xS with the same problem. Once I hit 95+ mph (in Mexico, of course) I can hear a whistling sound from somewhere on the right side of the car.
si_driver is offline
Old 11-10-2016, 01:16 AM
Ricio1991
Liked 110 Times in 101 Posts
Same here it's annoying
Ricio1991 is offline
Old 11-10-2016, 09:09 AM
si_driver
I have had this happen pretty much every time I go faster than 95, to me it sounds like it would be coming from somewhere around the door handle. It's possible the the wind is hitting the door handle and making the noise, but I never happens on the left side of the car. Weird.
Old 11-10-2016, 09:26 AM
Elco
Liked 30 Times in 27 Posts
It may be something related to the gas door.
The gap between the gas door and the rear panel might cause that sound.
My sedan makes the same noise since i got it. However, i never got that sound on the convertible. But the convertible gas door is placed different than the sedan.
Elco is offline
Old 12-12-2016, 12:13 PM
MrTLFsr
Liked 8 Times in 8 Posts
On my 2011 sedan (6sp) it's more like a deep humming sound at higher speeds, which I don't venture often.
My old Mazda6 did the same thing back in the 90's.
MrTLFsr is offline
Old 12-22-2016, 09:44 AM
Bionicman
Liked 7 Times in 7 Posts
2012 G37xS w/ 32k miles here, exact same issue at the same speeds for me, however, it's more of a mechanical high pitch noise than a whistle. Sounds more like a wheel bearing going bad. If it's transmission related, I'll find out soon because I'm fairly certain that my transmission will be entirely replaced in the next week or two. (transmission blew up yesterday)
Bionicman is offline
Old 11-02-2017, 09:44 AM
Bionicman
I was correct that my wheel bearing was bad, but having it replaced didn't eliminate the annoying high pitch noise at high speeds.
Old 11-02-2017, 01:00 PM
slartibartfast
Liked 609 Times in 537 Posts
I experienced a wind-caused whistle/noise from my passenger side mirror at 80 mph on the highway. I don't normally travel that fast so it's not been something I worry about. Oddly, I did not hear it when doing 105 mph at a race track in August.
slartibartfast is offline
Old 05-04-2018, 01:33 PM
nicaland
Liked 0 Times in 0 Posts
My 2012 6MT sedan has a very annoying noise that is definitely speed related that may be what others on this forum have experienced. It's best described as a loud humming/howling sound that appears to be coming from somewhere close to the right side of the windshield or the right front door, and starts up around 80-85 MPH, or less if bucking a strong head/crosswind, changes to a lower frequency and becomes louder as speed increases, and becomes VERY loud over 100 or so. However, if I crack open the moonroof it stops completely, so I feel that it must be a weatherstrip, window or door seal issue. This is obviously going to be a problem for a dealer to diagnose because of the speeds that need to be generated to duplicate the noise, and I'm sure that a lot of folks out there are going to say to just slow down, but where I live 75-80 MPH is required to stay with the traffic flow, and bucking a 25 MPH headwind at 75 will generate this noise.
Has anybody experienced this and found a remedy? It's really annoying, especially in such a refined car that otherwise has little to no other wind/road noise. I plan to head to a local 75 MPH speed limit road when the wind is blowing hard opposite my direction of travel, and start selectively applying masking tape around different seams to see if I can isolate it, and hope that I don't get a ticket in the process, and will definitely be relying on Waze and my Valentine to help in that regard!
nicaland is offline
Old 11-08-2018, 03:31 PM
cwhepler
Just bought a 2010 G37 sedan. Had the same noise above 60 MPH. Dealer diagnosed it as rear fixed glass seal. Known problem. Wants $300 to replace fixed window seal. I will buy some window sealant and see if it fixes the problem.
cwhepler is offline
Old 11-12-2018, 12:25 PM
nicaland
Sorry for the delay in responding cwhepler and thanks for the response. This message hit my spam folder and I just found it. I have read prior reports that this rear glass seal issue is a common source of this noise, but I'm 99% sure that mine is coming from the front right hand side. Having been out of country for two months I have yet to try to isolate it by taping up different seams and/or having someone else drive the car so I can use a piece of fuel hose and listen for it. I'll let you know what I find after doing so, for sure.
nicaland is offline
Ra_BiiGGa
11-03-2016 07:04 AM
DJMAC
10-16-2016 08:24 PM
isosunrise
24
09-22-2016 12:24 AM
capnmorganxx
09-13-2016 03:10 PM
Quick Reply: Help Weird high pitch noise on G37x 2012 Auto on highway speeds 70-80+ mph
Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
