Built Motor vs. Nitrous Setup
Old 06-03-2016, 02:19 PM
Upscale Speed
Upscale Speed's Avatar
Originally Posted by ANMVQ
Doesn't that stink man, we have NO ONE to install FI,nor tune us :/ ..
It does but not the end of the world I guess. Nitrous 125 shot plus meth kit should get me just as far as the SC would have. That's cool with me. Plus the torque should be a little higher.
Old 06-04-2016, 10:15 PM
PongSanity
PongSanity's Avatar
Look into getting this fuel port.... It'll be an ease for a fuel supplier
https://www.z1motorsports.com/z1-pro...rt-p-9160.html
Upscale Speed (06-05-2016)
Old 06-05-2016, 11:57 AM
Upscale Speed
thanks Pong I will order that too. Sounds like a great addition to the system and cheap too. Love it. Any other suggestions like that would be greatly appreciated.
Old 06-05-2016, 12:52 PM
NeverBoneStock
NeverBoneStock's Avatar
As long as you can find a shop who knows what they are doing with nitrous you will be fine. I have gone through 60 bottles on my NX kit with zero issues..
Old 06-05-2016, 05:37 PM
Upscale Speed
How long is a bottle lasting you? What is it costing you per pound in your area?
Old 06-05-2016, 07:35 PM
NeverBoneStock
I run 2 10 lb bottles and it's about 40 to refill here in Oregon. Bottles can last awhile or go really quick. I have nano assist bottles as well and it does make a difference. Indent spray all the time. That's why I purchased a FI TT KIT. I need to get off my *** and install it though
Old 07-02-2016, 03:54 PM
Upscale Speed
I'm going to be getting my NX kit installed in the next 2 weeks. I have a few more questions. I'm going to install 1 step colder plugs (GTR stock plugs) as I will be running 100 shot. I have a Progressive controller too. Also switching to test pipes.
1. Should I upgrade the fuel pump now? If I decide to go up to 125 shot will I need it?
2. I don't have a local tuner to dyno tune with nitrous, I have EcuTek and can have Visconti e-tune me a nitrous MAP but I'd need to data log. Is this safe?
3. How would you recommend I have the Progressive controller setup? Based on Time, RPM, MPH or Throttle Percentage?
4. Should I upgrade my injectors?
Old 07-02-2016, 05:53 PM
PongSanity
PongSanity's Avatar
I'd say no, it doesn't need to be upgraded but it won't hurt to get a walbro 255 or aeromotive 340 in there. Safe than sorry.
Street tunes are fine. Visconti reputable enough. If there is a dyno near you, just etune on there. Pay for the time to get such a task done.
RPM
Yes. GTR injectors at minimum.
Responded inline buddy.
Upscale Speed (07-03-2016)
Old 07-03-2016, 01:19 AM
Upscale Speed
thanks Prong I'll look into fuel pump and injectors now.
Old 07-07-2016, 08:02 PM
Upscale Speed
Got an aeromotive 340 and injector dynamics ID725 injectors. Should be good. Any other suggestions? Install date being pushed a little due to shops being so busy right now.
Old 07-07-2016, 09:21 PM
PongSanity
PongSanity's Avatar
Idr if u got gauges in your setup but the innovate nitrous all in one gauge is a good start ( http://www.innovatemotorsports.com/products/psn1.php ) also hit up GaleForce on the370z.com ( I can PM you his name on fb if you not on that site), he can get you a custom A pillar gauge pod that's OEM quality. Also one step colder spark plugs (GTR spark plugs would work).
Old 07-07-2016, 09:34 PM
Upscale Speed
Got a gauge cluster and GTR plugs. Do you think those with 125 show would be cold enough? I will need to have Visconti retard timing 2 degrees. Do you think that's enough?
Old 07-08-2016, 08:52 PM
PongSanity
PongSanity's Avatar
They'll be fine.
Old 07-25-2016, 09:59 PM
  #29
Upscale Speed
Pong where did you install your gauge pod? Any pics to help me? I'm getting mine installed starting Friday into next week.
Old 07-26-2016, 12:21 PM
  #30
ANMVQ
ANMVQ's Avatar
I had mine here Nice hidding spot
