R2C's installed
It being my only performance mod so far, I'm pretty happy. Where you really really notice it is under hard acceleration. The car sounds 100x better than stock when you're on it.
Easy install, took less than two hours. I used the stock hoses. The only modification I had to do was cut about an inch off of the passenger side hose. Next to install my Eibach sways that are in the garage...debating taking it to a shop simply because I don't have a good way to really get the car off the ground. Maybe FI CB and HFC's after that... |
nice. a set of $40 rhino ramps would probably be enough for sway install.
| All times are GMT -4. The time now is 05:26 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
