Dealer Replaced Manual Transmission Under Warranty
Definitely not normal. I had this problem as well. Apparently the 5th gear synchro on our cars is garbage. Luckily my dealership was cool and replaced mine free under warranty. I had 40K miles on it before I had to get it replaced. Mine started like you, where it got notchy every once in a while. Then one day it seemed like every other shift into 5th was grinding and notchy. I took it in had the service tech drive it around, then they replaced it in 3 days. Also Does anyone know if the transmission they give us are brand new or refurbed?
For you 5th gear guys, how often does it grind? I've had mine grind if I go in aggressively, a couple times in normal situations. Mostly when cold weather. I only have 900 miles left on my warranty and I know it will get worse :/. 2nd grinds occasionally as well, but only on aggressive shifts. On aggressive shifts, even when it doesn't grind, it is EXTREMELY notchy.
I had them look at it once and they drove it down the block and told me nothing was wrong.
My 5th gear would grind, I basically had to granny shift. When I changed tranny oil, it made the issue more obvious, it would grind no matter how I shifted. It was the syncro. So I brought it to the dealer thinking that there is no way they can say they can't replicate it. And then its done.
Darkstar752 (04-09-2014)
Cr0tchf4i
08-19-2015 03:52 PM
Badgerman
08-19-2015 02:26 PM
