Proper interval to change atf for 7-speed auto
I have a 2009 G37 with 60,000KM (37,500 miles) and wonder what the recommended ATF change interval is.
Going through the G37 Service and Maintenance Guide with service schedules of up to 120,000 miles, I don't see any mentioning of changing the 7-speed auto's ATF. Whenever ATF change is mentioned, it always says "Except 7-speed automatic transmission". Your inputs are appreciated. |
Originally Posted by G37beijing
(Post 3405534)
Originally Posted by MACS
(Post 3405626)
He said he already read the service manual and could not find anything before 120,000 miles. Way to waste his time by posting the manual.
i would imagine wasting time would have been just to tell him to do a search on these forums, or maybe not offering something constructive by telling other people they're wasting time when they're just trying to help. OP, i would call the service department at any dealership and ask them if and when one should change it. i believe there's a magnetic drain plug on the bottom back-side of the transmission and that it's filled through the dipstick on the back of the engine(read that somewhere on here a while back). good luck. |
Originally Posted by soundmike
(Post 3405630)
Infiniti doesn't recommend changing the ATF on the 7. However, if you want to do it, it's possible. I change mine every 30-45k (drain/fill).
I personally don't agree with that practice but I think I have a great SA :) |
It is designed to be a lifetime fill. Believe it or not.
Originally Posted by Coprolite
(Post 3405834)
Service rep at infiniti said 60k for tranny and 30k for pumpkins, not sure if this is in line with the manual though.
it's designed to be lifetime, but i personally would drain it around 60K, if you're looking to keep your car for a long time... If you're planning on selling it @ 90K, then i guess it doesn't matter :)
Originally Posted by sammy917
(Post 3405923)
service tech reccomends every 30k. i didnt know the 7s were "lifetime" does anyone know about the 5AT?
Originally Posted by Austin713
(Post 3406005)
Originally Posted by hadokenuh
(Post 3405777)
There is no fill plug.
https://www.myg37.com/forums/2927203-post6.html It's possible, just not an easy process. |
