Driveshaft Upgrade
Old 01-13-2018, 05:53 PM
  #91
RadioFlyer
RadioFlyer's Avatar
^+1. You changed two things that could cause that specific noise. I would put the stock driveshaft back on to rule out the diff. You might also want to double check the torque on the half-shaft bolts that connect to the diff output. These cars are already extremely sensitive to small changes in the rear axles/diff (rear axle click if it's not installed just right), so changing the diff, WHILE reassembling the whole system, WHILE changing the driveshaft, introduces a lot of variables all at once.
Weirdly, when I changed my diff, I first had a slight vibration, but it smoothed itself out in a few miles. I basically slapped it back together, drove it lightly for a few miles, like 30 miles or so, and then a couple hard launches. Then I double checked all the bolts, and it's perfectly smooth now.
Old 01-16-2018, 01:28 AM
  #92
Calg37USMC
Calg37USMC's Avatar
Just placed an order with a local DriveShaft Shop in Seattle area I will let you all know about my experience and feedback on the product.
Old 01-16-2018, 12:49 PM
  #93
zer099
zer099's Avatar
Calg37USMC: you are in a sedan or coupe? I see your a manual, that correct?
Old 01-16-2018, 12:57 PM
  #94
Calg37USMC
Calg37USMC's Avatar
Sedan 6mt.
Old 01-20-2018, 10:01 AM
  #95
Mattlorentzoe
Mattlorentzoe's Avatar
When I switched to 17 inch rpf1 and changed tires lost a good bit. I can definitely feel it on the top end. At least 10lbs on each corner.
Wondering if 10-15lbs saving on the rear driveshaft is worth the $1000....I lost that with each wheel at $220 per rim...
had as a shop out here in Georgia give me an estimate and said they could do it but just having a hard time with the money.
It makes cents though. Wish i could get both driveshafts for around $1000 or so installed.
Also not a fan of the idea of the aluminum breaking and it going crazy at 120mph... maybe that doesn’t happen but no matter the money I would have to have cf just because of that. It would be the only carbon fiber I would ever put on my car lol
Old 01-20-2018, 12:23 PM
  #96
zer099
zer099's Avatar
That's why you install a driveshaft loop.
Calg37USMC (01-20-2018)
Old 01-20-2018, 02:42 PM
  #97
Mattlorentzoe
Very true lol!
Old 01-25-2018, 01:46 AM
  #98
Calg37USMC
Calg37USMC's Avatar
DriveShaft is done! I’ll post pics later and review.
Bravo at (01-25-2018)
Old 01-25-2018, 10:36 PM
  #99
Calg37USMC
Calg37USMC's Avatar
Some pictures for you guys. I’ll post a review later when I actually drive the car.
Went with a local shop called NW drivelines. 3.5” Aluminum with 1350/1355 yokes. I forgot to weigh the DS but it is significantly lighter then the stock 2 piece.
Old 01-25-2018, 11:01 PM
  #100
slartibartfast
slartibartfast's Avatar
Please explain the yoke numbers. New to me.
Old 01-25-2018, 11:10 PM
  #101
Calg37USMC
Calg37USMC's Avatar
1350+ are truck u joints but can also be used for high power applications. It may be over kill but if I’m spending money might as well do it right the first time.
Hopefully that explains it. I honestly hate typing but love the site and you guys so Please bear with me
The following 2 users liked this post by Calg37USMC:
RMB5190 (01-26-2018), slartibartfast (01-26-2018)
Old 01-25-2018, 11:56 PM
  #102
slartibartfast
Well, that's more than I knew an hour ago. One of the parts to a car I really never had to deal with though I did help replace a few and have seen the bearings. If one went bad, you just bought a replacement.
Calg37USMC (01-26-2018)
Old 01-26-2018, 12:17 AM
  #103
Calg37USMC
Calg37USMC's Avatar
Yea man I had no choice I blew the stock one so I had to replace it and the cost for OEM DS from Infiniti is far more expensive than this aluminum piece.
Old 01-26-2018, 07:32 AM
  #104
RMB5190
RMB5190's Avatar
Very interested in the review.
Calg37USMC (01-27-2018)
Old 01-26-2018, 10:03 PM
  #105
ZahyMatar
ZahyMatar's Avatar
In for a review!! Definitely interested.
Quick Reply: Driveshaft Upgrade
