Do G37's have manifold vacuum with VVEL?
I have been reading about G37's while I wait for my new Slate Blue 6MT to be delivered to the dealer and I have a question about VVEL.:)
As I understand it the G37 does not have a throttle valve and instead controls engine output by using the VVEL system to control the lift and duration of the intake valves. http://www.g37-tech.com/wiki/VVEL Did I get this right? If so, with no throttle valve, does the G37 have manifold vacuum? |
Originally Posted by digitalis
(Post 2685479)
As I understand it the G37 does not have a throttle valve and instead controls engine output by using the VVEL system to control the lift and duration of the intake valves. http://www.g37-tech.com/wiki/VVEL Did I get this right? If so, with no throttle valve, does the G37 have manifold vacuum? This site lacks any serious technical information. I would highly recommend another site for technical information. I am not sure if I am supposed to do this, but I would recommend www.370z.com as the best site for technical information. You will learn more on there in 5 minutes than you would on here in 2 weeks.... Here is a link to a great article that talks about the above subject. I basically ripped off my answer from Mike Kojima (the man behind the site). Link: http://www.370z.com/MagazineArticles...e-VQ37VHR.aspx The answer to your question is on the 2nd page of that article. I have to say the VVEL system in our cars is pretty amazing. I was always told it was like VTEC, etc., but it really is a industry changing concept. It also is what requires us to run the Ester based oil, and pay $100+ for an oil change.... |
| All times are GMT -4. The time now is 11:18 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
