I should have clarified. I meant for their VQ35HR Twin Turbo Kit. because if it can work with the FX35 and M35...that's huge.
I would venture to say that the kits will mate up to the car just fine, but custom tubing would be needed. Tuning would probably require a piggy back or stand alone. Not sure if Osiris is available for those platforms.
In short ... I'd say yes it could be done IF someone wants to be the first.
SICK!!!!!!!!!!!!!!!!. Would it be possible to program the ecu to run low boost from 1st to 2nd then full boost from 3rd to 6th? I think think this will be better for the transmission.
The ECU cannot control boost, although you can achieve this with the HKS EVC6 boost controller.
Where did you guys relocate the washer fluid tank, or did you just remove it all together? Is there anyway to get smaller IC with the kit so the front bumper doesn't have to be removed? No front bumper makes for a really bad day if you hit something I had to remove the front bumper on my RSX when I turboed it and I never felt very comfortable with it.
Exactly. The plastic is the bumper cover, the big steel beam that is removed when mounting the IC is the actual bumper. Without that it's just plastic, IC, radiator, engine. Nothing to protect the IC/piping/radiator from minor fender benders. Obviously a major accident is going to F it all up anyways, but the bumper would help against minor accidents and allow you to drive away from it hopefully.
