Unv-it's Dyno
so we did a dyno run tonight on my car at the shop just to compare from the last one to see what the difference in weather is doing to the car down here in hot humid south florida. we did 15 pulls the first was the highest. same trend as last time.
last dyno specs January max power=289.91 temp=47 degrees humidity= 12% this run May Max power=267.26 temp=86 degrees humidity=27% big difference in power. but these are the same trends we are seeing in all our dyno runs that we did around winter time on all our cars. the heat and humidity is killing power. also our dyno is above ground and the lifted fan we use which we put right in front of the car and blow directly into the grill area's took a **** so i had no fans blowing air onto the car so it genereated A LOT of heat. i wasnt able to get a TQ reading as my ignition wires were not reading right and it was spiking the rpms all over the place. it would jump from 3k to 7k out of no where. so i was only able to get hp this time around. i will be doing a couple more runs once i get the injens here. pre intakes and post intakes. |
wow... mmm injens... only another month... wait wait wait...
wowo crazy # jump
Originally Posted by solopresident
(Post 2325612)
wowo crazy # jump
Bienvenido a miami!
you do know jersey humidity sucks balls right?
Interesting....cannot wait to see the before and after from the Injen.
Wow thats a HUGE difference in power... I know conditions play a part in performance but that's the biggest jump I think i've ever seen... :eek:
do you really think its the humidity? does car feel slower these days?
(Post 2326194)
dynojet?
re do it for us.
Originally Posted by cvt
(Post 2326246)
dynojet?
(Post 2326273)
re do it for us.
what clutch and flywheel...? i want to order a new clutch bad
| All times are GMT -4. The time now is 11:15 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
