K&N Filters
What is the part number for the K&N OEM replacement filters for the G37? I havent found the G37 listed on the K&N website. Is the filter the same as the G35 coupe?
if anything, it'd be the same part number as the 07 G35 Sedan as they're nearly the same intake setup.
Just out of curiousity, why would you change from the stock air filter?
the theory is K&Ns are designed for performance. they allow more air flow while still protecting the engine from particles, thus effecting more HP/TQ due to the increase in airflow. plus, they carry a lifetime guarantee and never need replacing, just a cleaning. this is the theory, for what it's worth.
Originally Posted by finagle69
(Post 2228363)
I am aware of the theory, and have used K&N's before, but I have never seen any test, other than K&N's own tests, that validate their claims. You have to oil the K&N filters, and oil attracts dirt, and the more dirt on the filter, the less air flows through it. |
Originally Posted by dmkozak
(Post 2228375)
http://forums.nicoclub.com/zerothread/180100 |
Thanks for the support. Somewhere there is a published white paper on the air flow through the 2007 G35's dual air intake system. It is the equivalent, or better, than the CAI systems available at the time of the test. Bottom line was that there will be little or no gains from switching to a CAI system on this engine or putting in anything other than a top quality stock-type air filter.
Originally Posted by Blk-G35
(Post 2228379)
Then read link shown in below and it'll change everyone's mind about changing their OEM filter with aftermarket intake systems.
believe ½ of what U see and none of what U read...
so would i be wasting my time with this?
http://www.stillen.com/product.asp?i...7%202DR%203.5L i need a radar detector first but i'm curious to see how wise an investment this stillen intake is.... AB g37 sport |
Just be carefull with the Stillen intakes, and any oiled filter for that matter... when i supercharged my G, i had a MASSIVE problem with Stillen over oiling the intake filter and the MAF getting the wrong reading, the car was constantly stalling and it was a PIA !!!!
=Xaerran= |
Let them all do what they want. Remember, we've tried to give some direction, but if people are going to be stubborn about this, then just forget it, let them find out the hard way. Then they'll be right back here asking us, trying to figure out why their car blew up or something.
I'll go get the popcorn started... |
(Post 2228379)
Really the only benifit of using the K&N's is the simple fact they will save you money in the long run by not having to replace them. Other then that its not really worth it. Your better off saving the money and buying a quality intake system when one is released...
the only benefit is saving money ? ok if you say so, I mean I guess its; new so it doesn't work. Wait for a better system, better how? I guess i like to waste cash.
