Help injector upgrade or stay stock
I am getting ready for a tune session in a couple of months and have read that with my setup, it is recommended to upgrade the injectors. setup will be as follow:
3" intakes
EPS 70mm throttle bodies
test pipes
Motordyne Y-pipe
cat-back exhaust
Michael Upton, who sells the intake, has mentioned that with 3" intakes, it flows enough air that it will cause the duty cycle of stock injectors to be in the 90% range. GTR injectors are pretty cheap and I wouldn't mind buying a set. Thanks.
Latez
3" intakes
test pipes
Motordyne Y-pipe
cat-back exhaust
Latez
3" intakes
test pipes
Motordyne Y-pipe
cat-back exhaust
Latez
3" intakes
test pipes
Motordyne Y-pipe
cat-back exhaust
Latez
Unless you're running E85 or some kind of forced induction, you shouldn't need larger injectors. If you can't hit your AFR targets because of injector duty cycle, then I suppose you could upgrade, but I can't imagine how any of those mods would really require that much more output from the injectors.
Latez
shawnberry45
06-09-2017 09:58 AM
cali_g37
02-26-2014 01:27 PM
MaxToTheG37
02-18-2008 02:55 AM
