Special ZSpeed Performance Stage 2 Easy-Street Clutch & ZSP BILLET Steel Flywheel NEW!!
ZSpeed Performance | High Quality
Stage 2 "Easy-Street" Quiet Infiniti G37 Clutch & Flywheel Complete Package
This is our #1 Best Feeling, Quietest Aftermarket G37 Clutch and Flywheel combo we offer for Daily Driving, HPDE & Light Track use.
Clutch Pedal effort in this kit is very similar to stock yet will hold upto 450TQ
Authentic Premium Quality Clutch Components (no Chinese parts here)
Our NEW Superior Quality ZSpeed G37 20lb lightweight Billet Steel Flywheel is manufactured 100% here in the USA and Milled from a solid piece of 4140 Billet Steel, We then add a high quality hardened steel heat treated ring gear.
Pair these together and you will have the best feeling, Quietest and most durable aftermarket clutch set you have ever driven in a G37. This kit will transform your G37 to a fun and pleasurable driving experience while keeping unwanted noise and drive-ability issues out!
This is the perfect Infiniti G37 clutch for Daily or Spirited use.
Kit Comes Standard With Everything You Need (less fluids)
ZSpeed Stage 2 Easy-Street Quiet Clutch Kit
ZSpeed CMAK V2 CSC Elimination Kit
ZSpeed Billet Steel Lightweight Flywheel
New OEM G37 Clutch Master Cylinder
OEM Bronze G37 Pilot Bushing
ZSpeed Insulated Stainless Braided Clutch Hose
Clutch Disk Alignment Tool
ZSpeed EZ-STREET Infiniti G37 Clutch Package!
The EZ Street is about as quiet as you can go with when going to a solid flywheel, most kits will rattle at idle, this is normally silent at idle, any solid flywheel will cause some low rpm take off rattle, this only occurs under 2500rpm when you load it up down low, once you pass 2200-2400 rpm the noise is no longer audible.
