Elongate rear toe bolt hole - what dremel bit?
Hashim - I took your advice and I bought a big bottle of Permatex anti seize. Now I will have silver sleeves and hands thanks for the suggestion. It makes sense. I'd rather wash grease off than have non-adjustable coilovers. It is a pretty simple decision when you think of it that way.
I searched for that Dremel bit on Amazon, and noticed in the results some cheap "tungsten carbide" bits for like $5 for 8. Like a stupid idiot, I bought them. Well, they are worthless. They cut for about 1/4 second until they were worn smooth.
So I am going to buy the real Dremel 115 today from home Depot and finish the job (I had to clean up and go somewhere yesterday)
interested as well op.
btw i did use those bits on the demon bolt once the cats were off. They worked on that steel so they should work on the steel sub frame.
Ok, I did it today after work. "Like butter" definitely does not describe how these cut, but I am sure if it was aluminum they would eat through it like no tomorrow! Still, they did pretty good against steel. I used one bit per side (two came in the package and it definitely slowed down after the second hole). It took me about an 1.5 hours to jack the car up, drop the spring buckets, and grind the holes. It probably took about 5-10 minutes of grinding per hole, the rest of the time was spent scratching lines in the metal, jacking the car up, positioning my body, and being enraged and angry. Also, it started pouring buckets of rain as I was putting everything back together in the dark, so I didn't get to install my rear camber arms.
The following 2 users liked this post by Infinibini:
Baadnewsburr (02-19-2019),
MStrike (01-24-2022)
LOL we have matching war wounds....
I installed mine Sunday and the 115 bit was not happy with what I was asking it to do. I picked up the 1/8 steel cutting bit and that made pretty quick work of the steel frame but was a rough finish. I then used the 115 to clean up the edges.
Redgoyabean
02-02-2018 02:02 PM
STownSaint
10-18-2017 09:35 AM
