Hella Supertone horns, with factory horns?
got my Hella Supertones, will be installing soon.
my question is, has anybody installed them alongside the factory horns (so that both sound when you press the horn button?)
was wondering if that would sound weird ...
i figured it would be easier to just vampire-tap the factory horn signal to the dedicated Hella relay and leave the factory horns in place, but not sure how this is gonna sound.
also need to see if i have the room to leave the factory horns in there ...
should have them in tomorrow or the next day - just need to pick up some connectors later. i have every kind except the one i need.
going to wire them in with the included relay, along with the factory horns.
if i don't like the mix of tones, it will be easy enough to just disconnect the stock horns.
then i wait for the jagoff who wants to cut me off with no turn signal .... HONK!
horns installed, Plastidipped stealth black behind the grille.
if anyone wants to do the easy install method, you can unplug the factory horn connectors and plug it right on to the Hellas. you may need to either remove the factory horn or make an extension wire to reach (using an MS connector to an FS connector, from the pic below.)
i decided to unleash the full fury with their own dedicated relay and larger gauge wiring. as of right now, they work with the factory horns. if i don't like it, i'll just disco them and leave the Hellas. when i went to test them real quick in the garage before re-assembling everything, i don't remember even hearing the factory horns because they seemed to be drowned out by the Supertones!
i installed them using the factory wiring and relay on my other car, and its been fine for over 5 years (don't know the relay rating or wire size, although i don't remember the wires being as skimpy as the G's).
i didn't really "test" them yet - just a quick honk to make sure they worked, but they sure sounded louder than the other car!
even with the "easy" method, you'll be WAY louder than the stock horns.
I installed them yesterday using the easy method. used the stock wiring with the stock relay, changed nothing but the horns. they sound louder but not as loud as I was expecting :/
I am impressed by the price of the unit, I got them for 28$ from amazon. Not so impressed by the loudness.
don't forget, they are directional - they may not sound as loud in the car. stand in front of the car and have someone give it a blast ...
they do sound different, not as bassy as oem ones.
I didnt have to remove the bumper but had to remove driver side air intake box to get access. that 500hz 2nd horn is down there, A bit tricky to get there but very doable. 400hz horn is right under the radiator cover so thats easy.
In that case, i should extend wires for the 500hz horn, since its kinda down there in car, probably facing sideward :/
coincidentally, i just used the horns earlier in a parking garage. yes, they're loud.
Youkickmydog24x
03-30-2016 02:29 PM
