Fluids and filters at 40k
Alright, So i got this car at 34k back in april and i wanted to swap out what is likely the factory fill in everything with fresh fluids before the weather stops being nice. I've been scanning the DIY's to figure out what i need and just wanted to run my shopping/to do list past the cognoscenti.
I tend to keep cars for a long time, well past 100k, because while i like nice things, I love having several years without car payments at a time. Obviously proper maintenance is critical to that goal. I don't race, but do occasionally ring it out so I will pay a moderate premium for things like quality synthetics, but not stupid money for superfluous racing fluids, so for any recommendations, i should be able to pick it up locally or order it on amazon prime. I feel like special order anything should be unnecessary, but certainly correct me if i'm missing out on something truly worth it. Did the amsoil thing in the past, good stuff, don't feel like paying for the privilege of ordering things from them again. Vehicle is a 2013 G37x Sedan So the engine oil and intake air filters are done. Here's the remainder of the list: -Front and rear differential: 75w90 all around, seems like the M1 stuff you can find anywhere should work fine? Procedure seems dirt simple -Transfer case: I have some amsoil low viscosity ATF left over from a previous vehicle, but I don't believe it's the right spec, so i'll just pick up some Matic J. Procedure, again, seems dirt simple. -Power Steering: The aforementioned leftover Amsoil ATF should be fine in this application. -Cabin air filter: Found the fancy tech package one is only a couple bucks more, so why not. -Brake fluid: I have an unopened liter of ATE super blue sitting on a shelf, any problems with using that? (either not the right spec or will require more than a liter to push through the old fluid). The DIY i found recommends a power bleeder. Is there any special procedure i'm unaware of that would preclude the use of a friends foot pumping the brake pedal? -serpentine belt appears to be in good shape, no cracking, but if i'm under there why not? Any preferred brand? Anything i'm missing? Anything i should check or get out of the way while the car is on jack-stands? Thanks in advance. |
Originally Posted by Victory
(Post 3952425)
I tend to keep cars for a long time, well past 100k, because while i like nice things, I love having several years without car payments at a time. Obviously proper maintenance is critical to that goal. I don't race, but do occasionally ring it out so I will pay a moderate premium for things like quality synthetics, but not stupid money for superfluous racing fluids, so for any recommendations, i should be able to pick it up locally or order it on amazon prime. I feel like special order anything should be unnecessary, but certainly correct me if i'm missing out on something truly worth it. Did the amsoil thing in the past, good stuff, don't feel like paying for the privilege of ordering things from them again. Vehicle is a 2013 G37x Sedan So the engine oil and intake air filters are done. Here's the remainder of the list: -Front and rear differential: 75w90 all around, seems like the M1 stuff you can find anywhere should work fine? Procedure seems dirt simple -Transfer case: I have some amsoil low viscosity ATF left over from a previous vehicle, but I don't believe it's the right spec, so i'll just pick up some Matic J. Procedure, again, seems dirt simple. -Power Steering: The aforementioned leftover Amsoil ATF should be fine in this application. -Cabin air filter: Found the fancy tech package one is only a couple bucks more, so why not. -Brake fluid: I have an unopened liter of ATE super blue sitting on a shelf, any problems with using that? (either not the right spec or will require more than a liter to push through the old fluid). The DIY i found recommends a power bleeder. Is there any special procedure i'm unaware of that would preclude the use of a friends foot pumping the brake pedal? -serpentine belt appears to be in good shape, no cracking, but if i'm under there why not? Any preferred brand? Anything i'm missing? Anything i should check or get out of the way while the car is on jack-stands? Thanks in advance. I think this forum is dead, I too posted a question about a month ago and no replies.....sigh |
Lots of threads on maintenance. Search and you'll find.
I used Dexron 6 for the PS fluid. That's what's specified in the manual, IIRC.
At ~ 34,000 miles it's waaay too early for the serpentine belt to be replaced. |
