Please help, steering wheel assembly broken
4 Attachment(s)
I was removing the steering wheel and trying to wrap the trim, however i pull out some assembly behind the wheel by accident , what's more is i broke some wire.....
i couldn't find anything online about how to fix this problem and i couldn't find the parts i need to replace either. i was so dumb, the dumbest on earth.........really hope someone could help me out :( |
How did you remove your steering wheel? Looks like you just ripped the clockspring out when you pulled off the wheel. My guess a wire from the SRS airbag was still stuck on a loom on the wheel or the connector for the accessory buttons was still attached to the clockspring when you yanked on it.
It's non serviceable so it will have to be replaced. I checked the usual orderinfinitiparts website but they don't have it for sale, however I did find it under another website supplier. CLOCKSPRING for 2008 Infiniti G37 B55541EA8A Safely buy online now - it's quick. Refer to the service manual for replacement. I'm trying to find where it is as I can't find it under steering. I will look for it and add a link once I find it. EDIT: Ok I should have known to look under the airbag section http://www.nicoclub.com/FSM/G37/Coupe/2008/SR.pdf |
thank you so much for you fast response, i really appreciate it!!!!!
i will look into it when i back home. |
No problem. Just heed warning to the service manual that improper install will snap the ribbon cables inside, which you'll have to fork over another few hundred bucks.
Originally Posted by Sunny Lau
(Post 3897655)
thank you so much for you fast response, i really appreciate it!!!!! i will look into it when i back home. Also, I'd see no reason why it isn't totally possible to get a used one from an auto salvage supplier (aka wrecking yard) for way less than new. .02 |
Thanks for the help guys!
Actually I was thinking is it possible to repair the ribbon cable inside the clockspring, and it seems feasible. But i don't want to mess up again so i found the part somewhere else cheaper and ordered it instead. Once again thank you for all the help, totally saved my life!!! |
Need Help
Hi this happenes to me too but in my case tge ribbon didnt break or rip but i dont know how it was routed inside and cant put it back together can someone show me like a picture of how the ribbon is routed inside please.
https://cimg1.ibsrv.net/gimg/www.myg...99dbd4c22f.jpg Can someone tell me or show me how the ribbon goes back on or how its routed, need help please its really urgent. |
Need Help
Help
Originally Posted by That08g37guy
(Post 4230982)
You will never get the ribbon back into place. Trust me, save yourself a hell of a headache and just replace the spiral cable. There are tons on eBay. Just MATCH PART NUMBERS!
(Post 4287541)
You are one lucky guy! Thanks for the update.
I agree with what ILM said. It can be quite tricky and sometimes impossible especially if you sever the ribbon.
Remember that the airbag wires have a specific resistance so if you sever the ribbon save yourself the headache and replace. If you pop the ribbon out of place you might get lucky however take your time with this. As far as the clockspring goes. Used units deliver for the most part and can be found for cheap if proper search is done. Clock springs are a common item to break especially on the V35s. Good luck! |
Originally Posted by BULL
(Post 4287585)
...the airbag wires have a specific resistance...
(Post 4287595)
That was the one thing I was nervous about when I did the Q60 (CV37) steering wheel swap. In order to get the heated part and the built-in paddles to work I knew I was going to have to swap the clock spring. Thankfully, Nissan does not change much when it comes to parts...I got lucky...
