Analog clock
Old 04-24-2017, 03:12 PM
DarienOG
DarienOG's Avatar
Analog clock
Hey guys, got a question for yall...
I can adjust the analog clock on my 09' g37 coupe and put it on time, but it will display the incorrect time the next day and i'd have to repeat the process. Anyone has had any similar issues? I'm going to test the fuse to make sure it's working 100% as soon as I get home, but I wanted to know what you guys thought in case the fuse wasn't the problem.
Old 04-25-2017, 12:12 AM
Epiphany
Epiphany's Avatar
Once you set the time does it stay correct for a while? If so it'll have nothing to do with the fuse. Fuses either work or don't, so if the clock is getting power and the time is moving your fuse is fine. Can't help you on it not keeping correct time, though.
Old 04-25-2017, 12:50 AM
crookncastle
crookncastle's Avatar
get a new clock. it has some sort of internal problem. its not the fuse so don't even bother.
Old 08-10-2017, 10:35 PM
aksansai
aksansai's Avatar
I have this same problem. My clock gains time when the car is off but tends to keep time on long drives. Odd.
Entcee
19
12-05-2017 03:29 PM
LssThanThree
07-22-2017 01:24 AM
Bommerang
04-18-2017 10:33 AM
Dbear13
02-11-2017 09:27 PM
Quick Reply: Analog clock
