MyG37
MyG37 (https://www.myg37.com/forums/)
-   D.I.Y. Installations/Modifications (https://www.myg37.com/forums/d-i-y-installations-modifications-11/)
-   -   DIY Mesh grill OP is "VT's G35S Sedan" (https://www.myg37.com/forums/d-i-y-installations-modifications/257919-diy-mesh-grill-op-is-vts-g35s-sedan.html)
blnewt May 4, 2014 11:53 AM
This is not my DIY but the OP is "VT's G35S Sedan", be sure to send him a thanks if you like this thread,
:)Are you a DIY kind of person????
Do you like the Audi's RS style grille?
Mine is the 2007-2009 sedan grille, but the newer 2010+ grill would look even better with this setup, IMO
I made one myslef, using Honeycomb Plastic mesh that looks OEM, and not that metal chicken wire stuff that all the aftermarket grills come with.
If you are a DIY person, cutt off all the blades and then fit the plastic the the grill, many ways to make it stay, from epoxy-fillers-or simply Hot glue(hot glue is basically melted plastic). It is actually much easier to make then it looks.
good luck on what ever you decide to go with
here is a link to where I posted my work in detail
The Grill- Yes i promised a DIY but never got time to sit down and type one up. Here is a link to the plastic mesh I bought off Ebay(be careful, and make sure you get this one :) because there are two options for the size of the honeycomb hole sizes, the One I have used for my upper grill- dimensions of each individual honeycomb 1.125in x 0.438in.) the other option out there is the 0.625in x 0.438in- I used this one for the lower bumper openings.
http://www.ebay.com/itm/Grill-Mesh-ABS-Plastic-Honeycomb-Euro-JDM-Sport-Universal-Sheet-46-5-x11-5-/321272999420?pt=Motors_Car_Truck_Parts_Accessories&hash=item4acd5cedfc&vxp=mtr#ht_2521wt_919
You will have to cut the the front chrome part of the grill horizantal blades off. I did this right at the point where the chrome face parts ends as shown in the pics. I used rotary tool with cutoff disks.
http://imageshack.us/a/img801/6899/zrz0.jpg
http://imageshack.us/a/img845/9132/7rvm.jpg
Then I ended up cutting off the side parts completely to be able to bend and tuck the plastic mesh behind the frame of the grill. So at the end you should only have the back part of the center horizantal blades left.
http://imageshack.us/a/img842/7743/zu0z.jpg
http://imageshack.us/a/img707/5439/v3fc.jpg
http://imageshack.us/a/img834/5047/3b8p.jpg
Sand the frame all around for it to be nice and clean looking and ready for the mesh itself. Tape it up agains the grill and cut out the shape of the mesh and with about 1/4" extra( to be tucked and glued or plastic welded to the back of the grill.
The Infiniti grill badge is completely optional. I myself will not be cutting the hole around it on my next attempt at this grill. you could also just simply get another Rear bage and mount it to the front grill for the cleanest look :)
Good luck guys.[/QUOTE]
http://imageshack.us/a/img41/1862/gvt7.jpg
warped ideas May 4, 2014 01:12 PM
WOW.... You got a knack for that stuff, Brad. Want to fly down to sunny S. Florida and do mine? LOL That looks pretty good IMO:biggthumpup:
RJ's_G37 May 4, 2014 01:51 PM
Looks awesome, might have to do this in the future.
G37Some May 4, 2014 03:40 PM
beautiful. I've always wanted the top grill to match like this, not sure if i have the nerve to do this though
blnewt May 4, 2014 03:41 PM
LOL, this isn't my DIY, I just posted this from a thread where the REAL author to the thread VT's G35S Sedan replied. But I wouldn't mind trying it however :)
© 2026 MH Sub I, LLC dba Internet Brands
