DIY: Serpentine belt change on an 09 G37
#61
The following 2 users liked this post by Gio37:
blnewt (01-14-2018),
Calg37USMC (01-10-2018)
jpowersjr2 (04-22-2018)
Dan G37 (04-22-2018)
#64
After running the car -
#66
#67
Just did this DIY last night. It's straightforward and it is easier going in from the bottom to route the belt. Also, Be careful not to lose your allen key between the radiator and fan shroud. I had a hell of a time trying to fish it out.
#68
Just say no!!!!!
Just did this this afternoon. Picked up the belt from rock auto for ~$25 shipped, pn BANDO MFG. 7PK2020A.
I didn't remove the bottom tray, but did remove the pulley immediately above and to the right of the tensioner. Ideally this service would be best combined with an oil change as the bottom cover is off already. Then it's easier to install to the lower pulleys.
Most challenging part was figuring out where to start with the install of the new belt. Top left corner (p/s pump) turned out to be the best place. Total time was about 2 hours, including bs'ing with the neighbor about the progress of road construction on our street.
I used a standard 3/8 ratchet with a floor jack handle for additional leverage. Original belt will be a spare. 31K miles, almost 7 years old.
Note, while belt is out, make sure to inspect pulleys for any roughness or binding. Replace as needed. All of mine were good. I couldn't reach the alternator to check but it's not making any noises, so will leave it be.
#69
#70
Despite my G being a slightly newer year, I've heard that modern serpentine belts don't show cracks or physical wear as you described. The main way to tell how worn it is, is to check the depth and width of the belt grooves. What I heard could be wrong, but it makes sense. My belt needs to be replaced at 107k miles, its squeaking when I accelerate and is showing NO classical signs of wear.
#73
Thanks again for the DIY. Knocked this out in 30mins this morning.
I do have a question....
My old belt was within the usable range B. And after installing the new belt it was also in range B.
I started the car and immediately checked the range, the indicator had moved all the way to the right, outside all 3 notches. (Photo attached)
I assume this means I need a tensioner replacement? Pulley #7 didn't feel as sliky as the others so I'll replace that as well.
Is the car ok to drive while I order parts?
2012 with 65k, first belt replacement ever.
#75
