Installing Stillen Gen3 Intakes Help
Hi, anybody have any advices, tips, warnings on installing the Stillen Gen3 intakes on a G37 Coupe? I've read people bought spaces or some kind of padding they used to keep the intakes from shaking? Neoprene rubber or something?? Could someone provide me some amazon links to this? I have amazon prime and would like to get it before this weekend before install
It's an easy install. The best advice I can give is to make sure you don't damage your MAF sensors and take your time installing. If you cut your holes well there shouldn't be any rubbing. If you want to cushion it, you can get some thick black adhesive thermal wrap that comes in a roll from a home depot, lowes, or other home improvement store.
Could you give me a brand? some specific name of that black adhesive thermal wrap? Possibly a link to amazon? Maybe a sample picture of what i should be looking for?
Thanks, now I'll know what to look for exactly a lowes this Friday
This is the one I have. It's insulation wrap that works great for padding.
Shurtape IT-100 Foam Pipe Wrap Insulation Tape at FindTape.com
Damn, finally installed it today. What a PIA to install. Had quite a bit of scratches on the bottom tubes Anybody know how to clear/clean these scratches? otherwise i'm gonna let it get dirty to hide Also seems the sedans are easier to install, and most of the tutorials are for the sedans? Cracked a bit of my radiator cover also .Overall, worth the growl
Here's my install, crappy passenger side. For others, be aware there is a metal thing inside the tunnel where you stick your pipes through that will scratch your pipe up good. Pad it. Learned it the hard way Its kinda sucks that it lays against the car chassis, and the passenger tubes don't align up 100%. I was hoping it wouldn't touch any of the car body, wiggled it around with no hope so only way to keep it off was to use padding. Hopefully it won't pop or break for the next 5yrs!
I did not attempt to remove my bumper. I only needed to pull the cover off(which you need to do anyways), pull off the grill, and used an oscillating cutter to cut the holes bigger. If you use a dremel, you minus well take off the bumper, or spend a few days trying to cut the hole bigger. The work area is very "small" on the driver side and i wouldn't know how ppl do it with a dremel.
It should be easy for a more experienced person, but for someone like me who's been looking at the forums, seeing how ppl break/yank/unscrew(rescrew) in so many places/having alignment issues on the the reinstall, it seemed scary and more troublesome work than using a oscillating cutter More space would of been nice, but not worth the trouble IMO.
