DIY: Front Bumper Removal Guide
I couldn't find one up here so i figured i would post this. Very simple and straight forward.
1. Fully open hood assembly.
2. Remove clips (A) of front bumper fascia upper side.
3. Remove radiator core support ornament.
4. Remove clips (A) of hood seal assembly (side) LH/RH with remover tool (B), and then remove hood seal assembly located front portion.
5. Remove bolts (A), and then remove bumper bracket (1).
6. Remove bolts (A) of fixing engine lower cover and front fender protector.
7. Remove fender protector (front) mounting bolts and clips, and then remove screw (A) of fixing bumper fascia left and right side.
8. Pull the bumper fascia side toward the vehicle side to disengage the fitting of bumper side bracket and bumper fascia side.
9. Remove bumper fascia assembly.
Wicked-G (07-30-2015)
Very helpful thanks for sharing man
I'm not a guy who does a ton of DIY on my cars, but I have changed the in-cabin filter, replaced the engine air filters (very easy), and changed out my battery (removed the under-hood cowl). Based on my low-level experience, what do you think the level of difficulty of this front bumper cover removal would be for me (1 being extremely easy and 5 representing the need to get a mechanic/bodyshop to do it)?
I would appreciate anyone's guidance on this one.
Thanks.
Thanks.
i know this thread is ridiculously outdated but I have to remove my bumper tomorrow and did not want to run in to any issues...
on #4, what is the remover tool that is referred to, to remove the hood seal assembly?
"Remove clips (A) of hood seal assembly (side) LH/RH with remover tool (B),"
leanlikeacello
08-15-2015 02:14 AM
