Detailer's Domain: 2010 Camaro SS - Full Paint Correction/Engine/Interior
39 Attachment(s)
Subject: 2010 Camaro SS
Requirements - Paint Correction/Engine/Interior Exterior - Wheels were prepped with Sonax Wheel Cleaner and cleaned up with various brushes - Tires were spritzed down with Adam’s All Purpose Cleaner and washed down - Wheel wells were cleaned up - Washed with 1Z einszett W99 - Aquartz Iron Cut - Wash down and rinsed - Door jambs were cleaned up - Nano Scrub AutoScrub - Dried - Tires dressed - Masking - Paint Measurement - Meg's D300 with Microfiber DA Cut Pad - Griots Orbital - Menzerna SF4000 with Uber Green Pad - Griots Orbital - Sonax Carnauba Wax - Inspection with Fenix, 3m Sun Gun, Infratech, and natural sunlight - Wheel wells were cleaned and dressed - Rubber and Plastics Treated - Exterior windows and mirrors cleaned and sealed - Exhaust tips cleaned - Windows were autoscrubed, cleaned, and sealed - Engine Detailed - Interior Cleaned/Conditioned/ Vac Products used Links to products used - 1Z einszett W99 Aquartz Iron Cut Sonax Full Effect Wheel Cleaner NanoSkin AutoScrub System Meg's M105 Meg's D300 Microfiber Correction System Menzerna SF4000 Sonax Carnauba Wax 1Z einszett Vinyl Rubber Care Optimum Metal Polish Engine Uber Engine Detailing Kit Interior 1Z einszett Cockpit Sonax Leather Foam Tools used Uber Wool Wash Mitt Uber No Name MF Towels Griot's 6 inch Random Orbital Polisher Uber Buffing Pads Defelsko Paint Meter Fenix TK35 Brinkmann Kranzle Pressure Washer Cam Spray Foam Canon 2 Grit Guard Buckets with Caddies Uber Firehose Nozzle Metro Air Force Blaster Metro Jumbo Vac N Blow Interior shots Before Attachment 168617 Afters Attachment 168619 Attachment 168621 Attachment 168623 Attachment 168625 Attachment 168627 Engine Before Attachment 168629 Let's have a closer look Attachment 168631 Attachment 168633 Attachment 168635 After Attachment 168637 Attachment 168639 Exterior Before Attachment 168641 Prep: Wash - Iron Cut - NanoSkin AutoScrub - Wheels - Tires Sonax Full Effect Wheel Cleaner cutting thru some nasty stuff Attachment 168643 Attachment 168645 Attachment 168647 Attachment 168649 Attachment 168698 Attachment 168651 Attachment 168653 |
Wonderful work as always. Love the clean black cars.
Very nice work and nice pics to show the difference.
Do you know anyone that does this work in the Dallas/Ft. Worth area and what price I should expect to pay...? You can PM if needed...
what was your process on the engine bay?
Did you use the foam canon and pressure washer? |
Originally Posted by Unique Bliss
(Post 3449649)
and don't laugh but I have the gilmour foam gun, It seems the Cam sprayer works much better because the foam sticks on the car and looks like it is a thicker foam, I've tried to get this with the gilmour but I just can't get it to come out quite like how your picture shows lol. Is this due to the fact that the Cam spray hooks up to a pressure washer and the gilmour does not??
thanks BTW excellent Work!!! |
Originally Posted by abice
(Post 3449656)
Did you use the foam canon and pressure washer? 1 dry engine (cold) 2 spritz all purpose cleaner on the engine bay 3. agitate if necessary 4. Rinse 5. Dry motor 6. start motor 7 Dress motor Uber Engine Detailing Kit |
(Post 3449659)
thanks BTW excellent Work!!! unfortunately the gilmour will never produce that type of foam. |
i've done engine bay detailing where I use a very light mist with a garden hose to rinse the engine, I'm very cautious around the engine, however, I've seen some detailer's foam the entire engine bay and then mist the pressure washer over the engine to rinse the foam and APC or degreaser, what would you say to this? Could you define your rinse step? Water and high pressure washer around electrical components of the engine just makes me nervous
That is sick, what does that usually run a customer?
(Post 3449656)
Did you use the foam canon and pressure washer? 2 let sit, use a boar's hair brush to agitate 3 with a good steady stream of pressure rinse the bay down 4 dry the motor with a good drying towel 5 start engine to complete the drying 6 use Adam's In and Out Spray to dress it Uber Engine Detailing Kit |
(Post 3449710)
we use a pressure washer at the shop to rinse off the motor. most newer cars are water resistant anything older than 1995 maybe a concern where I would cover sensitive components |
| All times are GMT -4. The time now is 01:52 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
