MyG37
MyG37 (https://www.myg37.com/forums/)
-   Car Care & Detailing (https://www.myg37.com/forums/car-care-and-detailing-318/)
-   -   Want a 4" backing plate for the Flex? Ain't gonna happpen. (https://www.myg37.com/forums/car-care-and-detailing/193125-want-a-4-backing-plate-for-the-flex-aint-gonna-happpen.html)
Black Betty Apr 8, 2009 04:35 PM
I asked Flex directly whether or not the would be coming out with a 4" backing plate. No dice. Here's the reply I got:
Originally Posted by Graham Briggs of Flex
Hi Jeremy
Unfortunately the technical design of the orbital head does not allow us
to fit a smaller plate. Inside the backing plate is a moulded
toothed track that gives the head its orbital movement, if we reduced the
size of this backing plate then there would be no room for the
corresponding gear from the motor.
Thank you and Best regards
Graham
Graham Briggs
Tel +49 7144 828-136
Fax +49 7144 828-323
mailto:Graham.Briggs@flex-tools.com
http://www.flex-tools.com
Too bad.
Raizon Apr 8, 2009 05:16 PM
How does flex compare to PC with the 4" plate? Going to get 1 for this Spring and dont know if i want to spend the extra $$$ for flex over PC.
Loi Apr 8, 2009 05:52 PM
BB,
I just switch from PC to Flex, and the Flex seems harder to control than the PC. It really sticks to the paint and sometime I can't get it to move smoothly like I want it to.
Black Betty Apr 8, 2009 06:14 PM
It requires more control because it has forced rotation and more torque than the PC. You can't bog it down by applying too much pressure like you can the PC. It takes a little bit of practice but the results are much better.
Loi Apr 8, 2009 06:35 PM
so dont press it down as hard as I usually do with the PC? what speed do you use to work in the polish?
Black Betty Apr 8, 2009 09:04 PM
I usually start really slow to spread the polish, maybe 1.5 or 2, and then turn it up after its started to break down. I seldom need to go over 4.5 or so. I don't use a lot of pressure and be aware of the position of the pad and the shape of the panel, if you use a lot of pressure or have it at certain angles, it will tend to "walk" on you. Just keep a firm grip on it.
I'm just learning it too, only had it for a few weeks.
© 2026 MH Sub I, LLC dba Internet Brands
