@mattlorentzoe’s G37x build (mid 12s n/a)
#241
Thoughts on supercharging Matt?
I also own an AWD sedan and someone at Soho told me last week that their single turbo kit won't fit AWD cars, but the Topgunz Supercharger and Soho air 2 air upgrade do fit. While the stillen supercharger will produce safe torque numbers for the 7AT, will the supercharger route wear out the motor quicker than single turbo with similar power levels. I believe I read that you we're considering supercharging the car which is why I ask.
#242
Supercharger would be cool but I’m also afraid I will loose reliability on track days and etc.!
Nitrous is for Mexico and the strip. My shop that built my car just bought a nitrous refill station lol.
wannabetoughguy (02-11-2019)
#243
Two more questions,
1) In order to do the lsd swap a custom driveshaft must be meausreed and fitted and a slide joint must be added to that custom driveshaft. Does that cover everything as far as the driveshaft is concerned? How would I articulate this part of the job to a shop?
2) In order to fit aftermarket headers with no rubbing or clearence issues on AWD cars are Z1 motor mounts all that is needed?
#244
So I have definitely hit the same road block. Was going to single turbo. Now I think I will go back to nitrous. Start with 100shot. I’m also acquiring another vhr motor to slowly build on the side. I’m constantly changing my mind but as of right now nitrous is the plan again lol. I was dumb to of sold my kit before lol I would be ready to go if I hadn’t. Lol sold the kit and was going to keep “as is” then blew trans not long after. Instead of taking the cheap route I decided to build it...haha now I got to much money tied up for it not to have some source of forced induction.
Anyways I'm sute you will go FI before the rest of us that plan to with our AWD cars so best of luck. My plans are FBO and a 75 wet shot not sure if a $7000 supercharger is worth the risk maybe the 75hp kit is best for longevity.
#245
Finally got new exhaust on. Couldn't be happier. No rasp at all with resonated test pipes and the 18 inch resonators. Super happy with the install it was very easy (wish I had a lift). The idle is so deep, sounds great.
Glad I went 2.5 inch. Entire 2.5 inch setup weighs 65lbs per fast intentions. Oem exhaust is roughly the same, around 65 as well so no significant weight change here.
Still waiting on some time to do valve body then it's off to z1 for nitrous tune. Hoping to make 400/350 wheel with 100 shot nitrous and a retune off bottle should be around 335/275 wheel.
#248
Lots of changes on this car. I am not longer tuned with admin tuning. Soho handles all tuning on my car now.
Also swapping in the (GEN 4)75mm conversion from rabbithole motorsports.
It consists of 3 inch intakes with welded on vstack, 75mm maxima Tb, custom oem ported plenum, ceramic coated port matched lower manifold.
The following 2 users liked this post by Mattlorentzoe:
jpowersjr2 (04-13-2019),
wannabetoughguy (04-15-2019)
GdaddyNY (05-19-2020)
#250
#251
Man I can't wait to see all this. Your exhaust looks great, Nik and SOHO really do a good job. He's supposed to be sending me a single turbo build quote (for my dreams lol) soon.
I'll be doing all the goodies from Rabbit Hole Motorsports as well. Then hitting up Moncef for an e-tune.
#253
jpowersjr2 (04-14-2019),
#255
Also I had major problems with royalty performance. Do not associate me with them for any reason. For those who tried to get into the group buy, I’m sorry it didn’t work out. I kept my bell diff brace and couldn’t be happier with its performance.
I will not be recommending them anymore. Sorry for the confusion. I am tired of having to have things done 2x. Soho is my new shop. They handle all major work and all tuning. Be on the look out for low 12s in the 1/4 mike this season.
zer099 (04-14-2019)
