Hotchkis G37 Sport Sway Bars!! In Stock and Ready to Ship Out!!
http://www.conceptzperformance.com/i...orumBanner.jpg Hey guys, Our latest shipment of those phenomenal Hotchkis Adjustable Sway Bars for the G37's just showed up! They are $369.95 shipped anywhere in the continental US. Simply click the "Add to Cart" icon to be directly linked to our website where you can place an order. PM or Email Me if you have any questions. Hotchkis 22441 Sport Sway Bar Set, G35 07+ RWD, G37 08+ RWD: $394.95 Shipped!! http://www.conceptzperformance.com/C...ages/3089l.jpg Enhance the cornering performance of your 370Z or G37 with a set of Hotchkis Sport Suspension sport sway bars. Our sport sway bar package increases front/rear roll stiffness giving the car crisp, quick turn-in response and balanced handling. As delivered the car has slight under steer and limited roll control. Sport sway bars give the driver the ability to rotate the car on corner entry and steer with the throttle when necessary. The dreaded under steer is eliminated and the handling becomes comfortably neutral with added traction during cornering. Hotchkis Sport Suspension sway bars feature a durable powder coat finish, greasable bushings, and brackets RWD Models Only! Features: • Lightweight, Durable 1 3/8" (35mm) Tubular Front Bar. • Lightweight, Durable 1.063 (27mm) Tubular Rear Bar 3 Way Adjustable • Premium mounting hardware including, greasable polyurethane bushings and heavy duty brackets. • Finished in durable anthracite powder coat. Benefits: • Brings handling excitement to your 370Z, G37 or G35 • Dramatically improves steering and chassis response • Increases stability, improves traction, reduces body roll by increasing front/rear roll stiffness • Easy bolt-on installation. Specs: Front Sway Bar 35mm (Ø1-3/8") Hollow +230% Stiffer than Stock G37 +205% Stiffer than stock G37S +230% Stiffer than stock G37S Rear Sway Bar 27mm (Ø1.063") Hollow 3 Way Adjustable +120, 175, 250% Stiffer than Stock G37 +5, 30, 65% Stiffer than stock G37S +50, 90, 145% Stiffer than stock G35S We Also Recommend: Hotchkis 22413 G35 Adjustable Sway Bars 03-06 Sedan, 03-07 Coupe RWD ONLY: $354.95 Shipped! http://www.conceptzperformance.com/Cart/images/466l.jpg Description: Hotchkis Tuning Sport Sway bars improve your handling and reduce body roll. Turn in with confidence and late brake in the corners with our track tested lightweight hollow sway bars. Sway bar sets include front and rear bars, greasable bushings, and brackets. Specs: Front 1 3/8" (35MM) Tubular(Bar Weight 13.5lbs) 4 Position Adjustable Rear 15/16"(24mm) Tubular(bar weight 5.5lbs) 3 Position Adjustable Bar Rates: 350Z & 03- 05 G35 Front Hole 1 = 1525 lbs/in (22% Stiffer than stock) Hole 2 = 1845 lbs/in (48% Stiffer than stock) Hole 3 = 2270 lbs/in (82% Stiffer than stock) Hole 4 = 2855 lbs/in (129% Stiffer than stock) 06 G35 Front Hole 1 = 1525 lbs/in (5% Softer than stock) Hole 2 = 1845 lbs/in (15% Stiffer than stock) Hole 3 = 2270 lbs/in (42% Stiffer than stock) Hole 4 = 2855 lbs/in (78% Stiffer than stock) Rear: Hole 1 = 520 lbs/in (80% Stiffer than stock) Hole 2 = 655 lbs/in (125% Stiffer than stock) Hole 3 = 840 lbs/in (185% Stiffer than stock) Usually Ships in 24 Hours We are also selling these NEWLY RELEASED Hotchkis Sway Bars: Hotchkis 22443 Sport Sway Bar Set, G35x 07-08 AWD, G37x 08+ AWD: $394.95 Shipped! http://www.conceptzperformance.com/C...ages/4459l.jpg Description: Enhance the cornering performance of your G35X/G37X with a set of Hotchkis Sport Suspension sport sway bars. Our sport sway bar package increases front/rear roll stiffness giving the car crisp, quick turn-in response and balanced handling. As delivered the car has slight under steer and limited roll control. Sport sway bars give the driver the ability to rotate the car on corner entry and steer with the throttle when necessary. The dreaded under steer is eliminated and the handling becomes comfortably neutral with added traction during cornering. Hotchkis Sport Suspension sway bars feature a durable powder coat finish, greasable bushings, and brackets Item# 22443 fits 08+ G35X, G37X AWD Models Only. RWD Models use item 22441 Features: • Lightweight, Durable 1 3/8" (35mm) Tubular Front Bar. • Lightweight, Durable 1.125 (28mm) Tubular Rear Bar 3 Way Adjustable • Premium mounting hardware including, greasable polyurethane bushings and heavy duty brackets. • Finished in durable anthracite powder coat. Benefits: • Brings handling excitement to your G35X, and G37X • Dramatically improves steering and chassis response • Increases stability, improves traction, reduces body roll by increasing front/rear roll stiffness • Easy bolt-on installation. Specs: Front Sway Bar 35mm (Ø1-3/8") Hollow +230% Stiffer than Stock G37 +205% Stiffer than stock G37S +230% Stiffer than stock G37S Rear Sway Bar 27mm (Ø1.063") Hollow 3 Way Adjustable +120, 175, 250% Stiffer than Stock G37 +5, 30, 65% Stiffer than stock G37S +50, 90, 145% Stiffer than stock G35S |
highly recommend the hotchkis
Bumped!!
Bumped!!
Bumped!!
Bumped!!
Bumped!!
Bumped!!
Bumped!!
Bumped!!
Bumped!!
Bumped!!
Bumped!!
been debating between these and eibach for quiiiite some time now...ugggh!
Bumped!!
