20x9 +35 255/35R20 Fitment
Hey guys I found a set of wheels with the following specs:
Sqaure set up 20x9 + 35 all around 255/35R20 all around Will these wheels fit fine? I'm worried the front might cause problems. This will be for a 2010 G37 COUPE. Thanks! |
Just fine, but if you have the sport brakes you'd need to confirm clearance there.
Big Brakes
(Post 4237737)
Im not sure if it will help determine if it will fit but the wheels are Niche Essen. |
If you can test fit that would be ideal, put some blue painters tape on the outside of the calipers just in case they are too close so you won't accidentally nick them.
YOu're RWD, right?
Should fit fine. I'd add some spacers though to fit more flush. Are you stock height? 255-35-20 seems kinda tall. I have 255-30-20 on the front with 20x9, +28 and have plenty of room. Then again, I'm lowered, so maybe stock height, you'd be okay w/those tall tires. |
Originally Posted by teahead
(Post 4241737)
YOu're RWD, right?
Originally Posted by SoloLeveling
(Post 4311183)
i have the same wheel set up(255/35r20) on my 2012 coupe AWD with the stock big brakes. I want to lower it an inch but i am worried about the front clearance. Even if i roll the fenders i think it may rub on sharp turn. What do you think?
To me a 255/35/20 is too tall for our (G35) cars, I looked into a 20” setup for mine and my findings were a 235/35/20 was a better fit, but to each his own. |
Originally Posted by Ponyryd
(Post 4311190)
Trick I use to tell is I jack up the opposite corner of the car and do a steering sweep. So if you’re worried about the front, jack up the r/r and do a sweep while checking clearance of the l/f, if it’s pretty close you can do the same on the other side.
