Help Staggered wheel setup on QX50
Old 03-31-2018, 06:19 PM
  #31
Dzionassi
Dzionassi's Avatar
Wheel Hubrings
Hubrings are not seated flush with a rim, will it be a problem?
looks like lip is little to wide....
Old 04-01-2018, 12:28 AM
  #32
Received 4,941 Likes on 4,174 Posts
Hmmm, wheel flange should be tapered away from the bore enough for those to settle flush. Those adapter rings look like most others as far as the thickness on top.
Old 04-01-2018, 01:11 AM
  #33
Dzionassi
Dzionassi's Avatar
I guess angle on the rim is different vs ring angle.
I could use belt sander now...
Old 04-28-2018, 12:09 PM
  #34
Dzionassi
Dzionassi's Avatar
Just a quick update:
It worked
blnewt (04-28-2018)
Old 04-28-2018, 02:48 PM
  #35
Glad it worked out, I assume no vibrations at speed?
Old 04-28-2018, 10:51 PM
  #36
Dzionassi
Dzionassi's Avatar
Did not go fast, up to 110mph. But yes, no vibrations. Handling on dry pavement is unbelievable. Will see how long conti's will last....
