Help Bolt-on wheel spacers with OEM wheels.
hello, guys!
I have changed my wheels to Q50 premium wheels which are 4x 19x9 et 47.
I already have extended studs in front and have 15mm slip on spacers installed. Now the rear wheels look awkward, they need spacers. I don't want to install extended studs in rear hub because of time / technical difficulty. I have a bolt on spacer borrowed from my cousin which fit his GTR wheels just fine but won't fit my stock Q50 wheels. the protruding OEM studs which hold the spacer in place don't go into the Oem Q50 sports premium wheel's cavities. I had the same issue with 370z sports wheels using same spacers.
Do people use bolt on spacers with OEM wheels?
If anyone knows for the fact that some spacer will fit, please let me know. I need 10 or 15mm spacers :/
hello, guys!
You see the cavities right beside stud holes? My understanding is that the remaining portion of OEM studs on which the bolt-on spacer is bolted should go to these cavities. this way the OEM bolts won't hinder the wheel installation. My problem is, they don't go into cavities. they hit the sides of the cavity walls and prevent wheel mounting.
Could this problem be the spacer specific? maybe it's the brand of spacer that I am using?
Some other brand bolt on spacers should not have this issue?
I will need 10 or 15mm spacer. if someone is using a small size bolt on spacers without issues, please let me know which brand.
A +47 is a lot of offset for a 9" wheel so you can run a pretty thick spacer, this should reduce the amount of stud/nut coming into that recessed area. A 15mm spacer should work well as far as fit at the fender if you're running a 245/255 width tire. I wonder if there's a smaller nut size that will still fit the 12x1.25 thread size, it's probably the edge of the nut that's contacting that wheel pocket rather than the stud, it looks like the pocket is pretty deep in that area.
How thick are the GTR spacers? If they are 15mm and studs are just barely making contact then a 17mm spacer might get it done. I had Ichiba 17mms before so I know they make them.
I'm having the same problem on my Q50, I have the exact wheel pocket on my Rays wheel and 15mm was a no go (H&R DRM style). I tired 20mm and it fit just fine however the wheels stuck out way too much (I too am running a 255/40 square setup). Ideally the 15mm was what I wanted but now I'm debating going 10mm or just leaving it the way it is. Not sure how much of a 10mm spacer will make, I really dont want to extend my studs to get a 15mm spacer to fit. My wheels is also 19x9 +47. Below was my 15mm spacer, rather than using the supplied nuts, I used Gorilla lugs for added safety, not sure if the thickness of the gorilla lug caused the issue? (damn now I should have checked before selling them).
Hmmm, too bad you didn't try a test fit w/ the supplied nuts, might have just squeezed in, they aren't great (the supplied nuts) as far as durability but are set up for a small footprint. They hold up ok if you're real careful about keeping the socket tightly seated and only use a 6pt socket on them.
I doubt it would work though, the circumference of the stock studs are bigger of that when you install spacers so the difference in the height would def cause the stock studs to hit the pocket in the wheel. Not sure if that made sense or not. I guess if you look at the pic I posted above and sort of eye ball the difference between that of the stock studs and then the spacer stud, the difference would def cause the studs to hit the pocket as pictures in the above posts by main_shoby.
