MyG37
MyG37 (https://www.myg37.com/forums/)
-   Brakes, Suspension, Wheels & Tires (https://www.myg37.com/forums/brakes-suspension-wheels-and-tires-305/)
-   -   Help caliper piston won't compress (https://www.myg37.com/forums/brakes-suspension-wheels-and-tires/267481-caliper-piston-wont-compress.html)
airman20012001 May 21, 2015 08:17 PM
My right front caliper piston won't compress so I can fit the caliper with the pads over the rotor. It is a 2010 g37x coupe please help:crying:
it's the front driver side
blnewt May 21, 2015 08:32 PM
If you have an old set of pads insert one and use a c-clamp to compress the old pad against the pistons, or a piece of wood will work too, unless the piston is seized :icon43:
airman20012001 May 21, 2015 09:04 PM
I used a clamp on the pad, what could cause a piston to seize? a ND what would I have to do? buy a new caliper?
HoldmyMouse May 21, 2015 09:16 PM
Did you open the reservoir cap before trying to compress the pistons backs?
airman20012001 May 21, 2015 09:50 PM
not at first but then I did, I was switching out the wheel hub and took the caliper off, tied it off to keep pressure off the lines. when I went to put it back on some brake fluid leaked out of the boot, did that have anything to do with it?
airman20012001 May 22, 2015 07:42 PM
So I took the caliper completely off, drained all of the fluid hit the piston with a rubber mallet and broke it loose. checked the seals they were fine put everything back together and it's working fine.
blnewt May 23, 2015 12:21 AM
Glad to hear.
Next time you may want to remove the piston in question and get a 3m pad and gently scrub around the piston sides, may have some corrosion that's causing it to hang up a bit.
© 2026 MH Sub I, LLC dba Internet Brands
