2011 G37x Brake rotor problem
Ok i ordered from autoanything the powerstop evolution front and rear brake kit. Came with drilled and slotted rotors and ceramic pads. The rear pads were correct but the rear rotors were smaller only allowing for half the pad to have rotor coverage and the fronts were also smaller not by as much. Autoanything says this is the kit for my car but obviously its not. Anyone have this issue and know what the size of the front and rear rotors are I have a 2011 g37x coupe not sport edition. The front is a normal caliper not the sexy sport calipers :-(. I do know what im doing as I am a collision and refinish tech.
Originally Posted by Jrwabw
(Post 3667908)
Front~ http://brakeperformance.com/images/d...tors/42095.gif Rear http://brakeperformance.com/images/d...tors/42093.gif G37X SEDAN Front http://brakeperformance.com/images/d...tors/42080.gifRear http://brakeperformance.com/images/d...tors/42088.gif |
ya after calling my old parts manager in clearwater fl I found that out. Thanks though that was exactly what i was looking for
Autoanything needs to update their part ordering system to specify whether you have a coupe or sedan. I received the wrong front pads from them recently. Its a big pain when you have rotors and caliper off only to find out you have to go back to your old setup while you wait 2 weeks for the exchange process.
Originally Posted by ai3j50
(Post 3671553)
ya they do. Then I had to hunt down the info for them really lol. good thing I was a paint shop manager at a infinity dealers collison center and still know my parts manager. They wont release sizes to the general public.
G37x Coupe
(Post 3667971)
Here's your correct rotor sizes~You probably got the AWD Sedan rotors(which I posted below your correct size)
Front~ http://brakeperformance.com/images/d...tors/42095.gif Rear http://brakeperformance.com/images/d...tors/42093.gif G37X SEDAN Front http://brakeperformance.com/images/d...tors/42080.gifRear http://brakeperformance.com/images/d...tors/42088.gif so i need the 330 Front & 330 Rear .... correct..? |
Originally Posted by rhdh104
(Post 3896286)
If you had the XS coupe it would be the big 355/350mm set but the coupe X is the 330/330 setup. |
(Post 3896535)
Yep, those would be the correct ones.
If you had the XS coupe it would be the big 355/350mm set but the coupe X is the 330/330 setup. 09 G37x Coupe Std Break Pkg, i cant seem to find the proper akebono pads and am nervous of ordering the wrong item from rockauto..... Would really appreciate it some help Thank You |
Originally Posted by Carfanatic
(Post 3926665)
Hey Bud , i could use your help with finding some Break Pads for my
09 G37x Coupe Std Break Pkg, i cant seem to find the proper akebono pads and am nervous of ordering the wrong item from rockauto..... Would really appreciate it some help Thank You It would appear that the two front pads they have listed are for the base coupe (330mm front rotor) and base sedan (320mm front rotor) Here's the F&R set at CariD AkebonoŽ - Infiniti G37 2009 Pro-ACT? Ultra-Premium Ceramic Brake Pads |
(Post 3667908)
Dies anyone else have a review for these on their G? |
Okay so which size rotors would i need for my 2012 g37xS sedan with the standard break calipers not the big sport calipers. 330/330?
Originally Posted by sptl99
(Post 3970444)
what size rotors/pads would i need for 2013 G37X sedan?
