niiiceee why 19 and not 20? pics?
Originally Posted by 08slate08
(Post 3370850)
https://www.myg37.com/forums/picture...ml#post3366393 thats my post. i still need to get around to taking more pics but there is one pic for now these wheels are heavy as it is, 20"s would be overkill. I used to have volks + 2 piece rotors all around which made my car feel alot quicker so i wasnt about to throw on some super heavy 20"s. also ride quality on 19"s are better and i already had tires, so just made sense |
they look nice i like the white on black... the weight thing isnt that big a deal but i see what your saying that you had tires i dont blame you tires are expensive... on another note cant wait to get my headlights painted makes the car look so much more aggressive
31 lbs??? damn... 31 lbs is def over kill... thats even heavier than stock... unless youre only going for looks... brakes, braking distance, gas, take off, suffer tremendously... performance wise, 19's are the way to go...
sick cars!!
I believe the 20's are 36.6 LB a RIM lol.. Looks nice but super heavy... think vossen is around the same weight also not sure xD
If i'm dropped on eibachs, what would be a good tire combo for 19" aftermarket rims and what size should i consider for performance?
You sure there 36 lbs? That doesn't sound right. The vossen cv3's are 26 lbs F and 27 lbs R. Almost identical to our stock 19's.
Originally Posted by R3al_L3git
(Post 3404114)
There u go from the man himself lol. Figured D would chime in on this one. Thanks 4 clarifying bro
My pleasure bro :) Not bad versus stocks.
Here is some additional info for our stock 19s. Front: Wheels: 19"x8.5". Cast aluminum. Made for Nissan/Infiniti by Enkei. Weight: 26.5 lbs. Bolt pattern 114.3 x 5 Offset +43 Tires: Bridgestone Potenza RE050A 225/45/19 92W. UTQG 140AA, weight 27 lbs., tread depth 10/32" Rear: Wheels: 19"x9". Cast aluminum. Made for Nissan/Infiniti byEnkei. Weight: 27.5 lbs. Bolt pattern 114.3 x 5. Offset +45 Tires: Bridgestone Potenza RE050A 245/40/19 94W. UTQG 140AA, weight 30 lbs., tread depth 10/32" |
https://www.myg37.com/forums/members...e-this-car.jpg
I just got my stance sc-5's also. They look sick! 20x8.5F 20x10R 245/35/20F 275/30/20 R Can't wait for my eibach springs and camber kits to get here next week. |
Originally Posted by Diego@Vossen
(Post 3404238)
the 20 inch CV3s are 27 LB for fronts and 28 LB for rears. All other Vossens are similar, LMK if you have any more questions.
Yes sir! Weigh the rims alone with no tire!
Anyone know if I could run a 20x10 or even a 20x10.5 in the sc5's up front without having to roll the fenders? I'm going for the deep concaved look on all four wheels. Also, what offset tires should I go with to make it work? I'm lowered on eibachs and have a journey coupe that I plan to put the IPL body kit on. Any help will be greatly appreciated!
