MyG37
MyG37 (https://www.myg37.com/forums/)
-   Brakes, Suspension, Wheels & Tires (https://www.myg37.com/forums/brakes-suspension-wheels-and-tires-305/)
-   -   Winter wheels and tires from Tire rack doesn't fit! (https://www.myg37.com/forums/brakes-suspension-wheels-and-tires/215422-winter-wheels-and-tires-from-tire-rack-doesnt-fit.html)
clozad1 Dec 10, 2010 08:30 PM
I just got a set of 18x8 silver painted Sport edition A7 with Michelin Xice Xi2 for winter but when I tried putting the rims on they don't fit! The rims doesn't clear that bolt that sticks out of the rotor so I can't put the rims all the way in because of that dang bolt. Has anyone had this problem because I thought since I bought it from Tire rack that it would fit but it doesn't.
da mayor Dec 10, 2010 08:51 PM
you need to take that bolt off... then it works.
123u Dec 10, 2010 08:52 PM
Originally Posted by clozad1 (Post 3017057)
I just got a set of 18x8 silver painted Sport edition A7 with Michelin Xice Xi2 for winter but when I tried putting the rims on they don't fit! The rims doesn't clear that bolt that sticks out of the caliper so I can't put the rims all the way in because of that dang bolt. Has anyone had this problem because I thought since I bought it from Tire rack that it would fit but it doesn't.
u supposed to removed those 2 lil small bolts from the hub, when u put on aftermarket wheels. 1 on each side on the front. what that is to prevented u from puttin the rear wheel to the front! that help?
clozad1 Dec 10, 2010 09:24 PM
Yes that helps. Thank you I'll try and do that and hope it works.
Vu37 Dec 10, 2010 11:12 PM
Wierd 09 6mt my didn't come with the those two front bolts. Does all g37 come with it?
clozad1 Dec 10, 2010 11:55 PM
I did what you guys said and took the bolts off. Tires fit perfectly can't wait to try them out in the snow. Thank you!
123u Dec 11, 2010 01:52 AM
im glad to see that u all set :biggthumpup:
TheMainAP Feb 12, 2013 05:45 PM
My winter tires + rims (same ones) are just getting put on now... had to search the good ol forum to make sure this bolt wasn't anything important. Things work perfectly now! Thanks to myG37.com and it's people, so stoked to be able to drive again!
Neal@tirerack Feb 13, 2013 02:47 PM
Yeah, that bolt causes more issues than it's worth.
© 2026 MH Sub I, LLC dba Internet Brands
