MyG37
MyG37 (https://www.myg37.com/forums/)
-   Brakes, Suspension, Wheels & Tires (https://www.myg37.com/forums/brakes-suspension-wheels-and-tires-305/)
-   -   Moving up to 20's (https://www.myg37.com/forums/brakes-suspension-wheels-and-tires/197471-moving-up-to-20s.html)
reddemon73 Jul 24, 2009 03:36 PM
Moving up to 20's
Hello everyone,
I'm sure this question has been asked to death so I apologize for not using the search function. I can never find anything on search.
Ok, I'm looking to upgrade to Vossen rims (83) and wanted to know are there anything I need to look out for before buying these baby. I have an 08 G37S with sport supension. I know I will be sticking with staggered setup. The question I have is will I need to lower my car? If so, what would you recommend? Do I need a camber kit? Will there be any rubbing issues? Anything else I left off.
Thank you,
DT
Blackjack Jul 24, 2009 03:52 PM
You don't have to lower, but you'll want to or else it will look funny. The most popular option for lowering is springs (Eibach Pro is the most popular one). However, you can also go with adjustable coilovers (KW Variant 3 is the most popular), but it has a hefty price tag. Depending on how much you lower depends if you will need a camber kit. I would highly recommend one as it will save you money in the long run even if your camber is only slightly affected.
Unless you slam it, you shouldn't have rubbing issues.
Hope that helps.
myk1013 Jul 24, 2009 04:02 PM
You might want to PM and ask those guys rolling on the Vossens. There's quite e few of them here. IDK how wide the rear wheels will be with their staggered fitments.
I have 20x10.5" +37 rear wheels with 285/30/20 Yokohama S.Drives and dropped with Eibachs. I do have the rubbing issues. They say it's much better with 275/35 tires but I dont like the stretched look.
Blackjack Jul 24, 2009 04:06 PM
I rubbed with 285/30-20. With 273/35-20, I don't and I'm slammed. The difference in the amount of stretch between the two is minimal. I've had both with Toyo T1Rs.
myk1013 Jul 24, 2009 04:16 PM
^ thanks, I may get 275/35 next.
reddemon73 Jul 24, 2009 05:13 PM
Thank you everyone for your prompt and helpful advices.
This might sound very basic but what is the ideal offset and bolt patterns for our car? How do I know if I need a camber kit?
G37Sam Jul 24, 2009 06:14 PM
The lower you go the harder it becomes for the mechanic to adjust your camber with just an alignment. With Eibachs, its common that you'd be good with just an alignment, any lower would require a camber kit just to be on the safe side.
Check out this lovely feature for more info
SOLISIMO Jul 24, 2009 11:12 PM
^^^^^^^^^^ guess your sig. isnt working very well after all^^^^^^^^^^
myk1013 Jul 25, 2009 12:18 AM
^^ ha ha, I didn't even notice that.
© 2026 MH Sub I, LLC dba Internet Brands
